Get a set of pmu clubracers and you cant go wrong. They have heaps of bite when cold so you can use them on the street with no problems
LOL, i bet you have ABS :)
I cant drive with bitey pads like some Hawks and Endless CCR. I just forever lock up and flat spot tyres :(
Lap 1
Lap 2
Lap 3
Lap 4
= SQUARE TYRES and reverting back to RB74 sporty street pads :)
I'm just about to do Phillip Island this weekend in my 32 GT-R with standard brakes and A1RM pads. Anyone have any idea of how they'll hold up at the island.
They were pretty average at Winton as they started to fade trying to pull up after the straights.
Do you have ducting for the front brakes? If not, throw some on there, will help.
Lap 1
Lap 2
Looks like you are doing better than old mate in the red car out the back? Reverse entry? lolz :P
  • Like 1
You must be trail braking alot to carry a locked tyre that far into a corner or is it that you had to stay on the brakes late due to an earlier lock up?
I used to use RB74's. But I found that once they went away due to heat they never would come back. Not sure why.
The DS2500 feel as though they have changed in the last set I bought. Alot more bitey when you first bed them in. After a few kms they reverted to how they used to feel.
His set are for R34 calipers so no good for me.
I'll check out OTR though, cheers for that.
Ah yes, you must have the Nissan brake setup.
Then the part number you need for PMU is F236.
Cause I upgraded to Brembo Calipers, I just see it as all interchangeable :laugh:
As the part numbers are all the same for R32 / R33 / R34 GTR (Brembo Caliper Only)
Which is PMU F206.
  • Like 1
Ive used the a1rm on about 4 track days and there not really confidence inspiring. They tend to let go after one or two decent laps and they wear out really fast. Waste of money in my opinion. Get a set of pmu clubracers and you cant go wrong. They have heaps of bite when cold so you can use them on the street with no problems
I have already haha. I bought a set of pmu clubsports of them which they recommended but i never fitted them coz i bought a set of alcons soon after with the clubracers which are a step up to the clubsports. There brand new in box if anyone wants them pm me
So you went from stock hardware with a1rms, to alcons with PMu.... Fair test? :/
Yes It is because my opinion is directed to the topic of a1rm pads on stock gtr calipers which is what people were talking about. The a1rm pads in my opinion, and im sure gsl will tell you the same thing is, a1rm is a very good street pad that you can take to the track and the clubraces are a track pad you can also drive on the street. It has plenty of bite when cold and when used on the gtr brembos will still be a big step up on the a1rm.
RB74s in my pad shape are dirt cheap. Something like $140. I have plenty of rotor and cooling so luckily able to get away with cheap pads. Am going to give RS4-2s a go next.
And yes,..I carry a fair whack of brake up to the Apex. I set my car up so its a bit dosey in turning as it is easier to wrestle the car to the apex and have good power down then a nice front end that the read doesnt want to follow and blases tyres on exit. Maybe a more switched on person could set the car up better but meh...it is what it is
I find my a1rms were fine on the track. But I have a much lighter car. How much are clubracers worth? I just looked it up at $350 for some fronts, so I think I'll be ok with the QFM product.
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
