Hello
So its sorta hard to explain, but ill try my best.
I have a 1998 R34 GTT Skyline, It has a rb25det NEO. It has no engine mods other then an oiled HKS Pod filter, Apexi Front mount intercooler and an Apexi AVC-R Boot contoller.
I have a problem (is most noticable in 3rd gear) where when i hit apoximatley 5000rpm power drops and from outside the car it sounds like im on red line apprently. I am still obtaining the same out of boost and injection percentage according to the Apexi AVC-R. When i set the boost at stock pressure the problem goes away. However the problem accours again when i turn the boost up. Starting at 9 psi and onward up to 11 psi! (i havent tried to go any higher) iver also tried it with traction control on and off and it makes no difference.
Please help, Do i need a tune or new plugs and coils, etc...
Thanks for your help, Im new to all this.
Alex
Edited by Shelford93
https://www.sau.com.au/forums/topic/426825-r34-gtt-problem/
jase_c I have hit boost cut before, this problem isn't as violet as that it doesn't jerk or throw me around it just looses power when I hit about 5000rpm and then it seems to get past it at about 6500rpm
https://www.sau.com.au/forums/topic/426825-r34-gtt-problem/#findComment-6886514
I would use a compressor and regulator, but you could perhaps use a bike pump and gauge?
Just remember the pressure it takes to open the actuator is completely different to where it will crack open normally, as the manifold is filled with pressure when the engine is running.
Best to simply leave it on low boost if bumping it up is causing issues, unless you tune it...
https://www.sau.com.au/forums/topic/426825-r34-gtt-problem/#findComment-6886811
Seems your running the stock ECU as you don't mention an aftermarket.
34GTT NEO's seem to always encounter this issue.
you could put an R32 actuator on there and stay on/around 10PSI
until you do get an aftermarket ECU or 'Nistune' and get it tuned as suggested by others.
Edited by Sinista32
  • Like 1
https://www.sau.com.au/forums/topic/426825-r34-gtt-problem/#findComment-6886820
My 34 is doing something similar around 4500rpm under load on the dyno but i think it has something to do with maxing my air flow meter out (240kw). i have some video of it i might try and upload, see if its what yours is doing
https://www.sau.com.au/forums/topic/426825-r34-gtt-problem/#findComment-6887883
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
