  • Replies 45
Auxiliary Air Control valve. From those sounds, I'd be looking at a fuel related issue. If cleaning the AAC didn't fix it, something tells me it might be fuel. Its hard to tell from the video but it sounds like its lean popping and not enough fuel at that RPM.
Ive had a number of coilpacks fail on me and most times they never presented a symptom at idle or free revving. I had a failing fuel pump. Car was hard to start, you couldn't free rev it, let alone drive the car without it gurgling, popping and carrying on.
cleaning out the AAC didnt change a thing, it was pretty clean anyway.
and i haven't tried another AFM yet, is it worth buying one to make sure the current AFM is not at fault?
and what do you mean by solder fixing my current one?
and i recently replaced the fuel pump but just with a generic after market one could that be causing the issue?
Did the problem only start after the new pump, or was it there before?
If it's popping at light throttle only then I doubt it will be pump related as it would get worse the further up the rev range.
I'd put it down to either an intake leak somewhere, such as a vacuum hose or gasket. There is always the chance that it is related to the tps sensor or crank angle sensor or even knock sensors though. Unfortunately, it really is a bit of a case of keep trying stuff until something fixes it though. You could try cleaning the throttle body and see if that helps at all.
I'm about to go through a similar battle with my Commodore. It has a misfire when just off idle (such as creeping along in slow traffic). I'm going to start by cleaning the throttle body, aac and intake (already done plugs at last service and cleaned afm)
Yes, some pumps don't like the low power the stock fuel computer puts out at cruise and idle. You can try running a temporary direct power feed, or just do the fuel pump rewire with a relay to prove the fault.
thinking back the issue was there before anything was replaced and its what initially made me start replacing coil packs and everything else,
my next step is looking for a vacuum leak as that is very possible
Maybe try resetting your ECU to see if it improves anything? As after reset, your ECU will be learning all the new parts you've replaced with?
Or just do a search on SAU on how to reset ECU, it can be done by putting a wire through 2 ports in the consult plug, saves you from disconnecting battery and having to set the radio again
so after all that chasing i just put 20ml of ignition cleaner in to 3/4 a tank and immediately as soon as i left the petty station i noticed the problem was gone, took it for a good drive and noticed nothing wrong and gave it a little rev in the driveway to see if it was jumping like before and nope clean revs all the way through!
im still unsure of why it was so instant, wouldn't it take a bit of driving to remove build up ect?
hopefully the problem doesn't return, im still going to reset the ecu and ill daily drive it for now just to see how it goes
so on second start after resetting the ecu problem is back
heres a better video with clearer sound of the splutter
http://www.youtube.com/watch?v=AkXuTjv5BQw&feature=youtu.be
any last ideas before i head to a mechanic?
The ecu fixed itself - it learned what the problem was and it was happy. Then you reset it. Now it is sad again. Needs more hugs.
    • Oh, forgot to add, A few months ago I was getting mixture codes and the car was using crap loads of fuel. You could smell the unburned fuel in the exhaust, it was crazy strong. Economy was over 17.5 l/100 and usually around 19. I smoked the engine and found a leaky CCV hose which I replaced and then I replaced my two pre cat O2 sensors, I also replaced the MAF. This fixed my mixture codes and improved my exonomy but I'm still 14 - 15 l/100 when pottering about town so something is still amiss. Throttle response is much better and it has more pep but I'd like to know why it's still so thirsty (and I'm hoping that whatever it is gives me a bit more poke).
    • Car is on factory injectors/z32 maf/ q45 throttle body/ z32 ecu with nistune
    • Hello all, currently finishing up a rb25 swap into my s14. Having issues with starting, car has spark (confirmed by pulling a plug and watching it spark), has fuel(confirmed by checking pulse/voltage at injectors all spark plugs are soaked in fuel). Car cranks over and pops into the exhaust with a heavy fuel smell but no attempt to start or run, I have torn the timing cover off and triple confirmed timing, turned the CAS in multiple spots both directions, attempted to start with coolant temp and maf unplugged, checked my fuel lines and made sure they weren’t backwards, checked voltage at cas/injectors/coilpacks, made sure all the grounds in the harness are connected and added a few grounding straps (1 from chassis to block, 1 from chassis to head, and 1 from chassis to igniter chip) I am getting stumped here. As a last ditch effort I made a full grounding harness tonight that’s going to run from the battery and add an extra ground from the battery onto the coil pack harness/igniter chip/ intake manifold/ Wiring specialties harness ground/ and alternator. I’m hoping maybe the grounding harness will fix it here but posting here to see if anyone has any other ideas on what else I can check. My fuel pressure is unknown right gauge will be here tomorrow.  IMG_3206.mov
    • yeah I was shocked when I checked my spare OEM on and as below that's how they come from Nissan. (side interesting note new NEO gearbox and replacement park lack the brass bush on the tips and its just all alloy) unsure about damage to the box currently back at 1110 to be pulled down/inspected and selector fork replaced as he built it previously and given the never before seen failure on his billet forks he is replacing it under warranty. He said he has used always OEM the keyway tab without issue for years so it could be an unlucky coincidence. I did talk to him about the sharp corners and stress concentration too. Re: hard shifts i got 7+ years out of the OEM one and the fork itself failed not the keyway. so could be bad luck as I said or an age thing + heat cycles in box and during fabrication of billet?
    • That's some really horrible design with the way it's cut/shaped! Is there much damage to the box that failed in? IE, new fork and you can go again, or is it a total rebuild again? Id be trying to build that piece from scratch, and getting some reliefs added in the corner to hopefully stop breakage, and then swapping boxes ASAP, and then doing the same to the currently good working box. I'm assuming hard shifts have not been friendly to it!
