So NSW Time Attack comes around. After the madness of getting the car ready and actually getting to the event.
285/35's are very tall, so we had to massage the tubs a little. With the castor and under load there was some rubbing.
  • Like 1
I've only been to Wakefield once and that was for the SAU Nats last year.
1.07 I think the time was.
So this time around I've got less weight, little more power and wider tyres.
1.04.9 on the coldest two days on earth, I though PI was cold in Winter, this place has nothing on PI.
It took a silly amount of time to get the tyres up to temp, we used so much fuel that after the second run on day two we had run out.
6x 20L cans and 60L in the tank, gone.
Most others were using Martini, which was no good and guys running Surogen were out and re-tuning for Martini.
  • Like 1
It's been decided that the splitter is not low enough to fully utilise the air and that the lower lip design wasn't the best aero wise.
So we knocked a template out of wood. We will be attaching the front in in a way that makes it easy to get on and off. Also need to look into the fasening system from the splitter, as that needs to be structural to the chassis not the front bar.
We also enlarged the intercooler opening, which isn't better for aero, but is for cooling.
  • Like 1
The wing sits low on the standard GTR stands, so up it goes 30mm. These are made from 3mm alloy, one on each side of the wing stay.
Also notice the go fast tape around the boot from NSW Time Attack.
Also trying out some F1 inspired wing end plates. The old man cut these out of 2mm alloy, with the angle grinder.
  • Like 1
Some toys to fix the diff. A little gearbox maintenance with a new seat for the shifter and a new selector bush.
Also people go on and on about roll center and bump steer. While I understand the mechanical theory, in practice on the track...mmm not sure.
My front tie rods are not even near horizontal with the car is jacked up and suspension unloaded. They are still a good 10mm higher at the knuckle.
So I'm smashing out good times, with the front arms pointing skyward. I think the car handles extremely well. So I'm further interested to see if these KTS rod ends make any measurable difference to the way the car handles.
We changed the studs over to 70mm NISMO's a while back and now I've got some real wheel nuts. 2 piece project mu's.
  • Like 1
Tyres, tyres. I know on the current set of wheels I can just squeeze a set of 285's on there. I'm sure 285/30 will fit no worries.
But....is there going to be a difference, even 0.1 seconds difference in going to a 295...
Now a 295 is going to bulgde the hell off a 10" wheel, so i'd need a 10.5. To do that the offset needs to be way out there.
10.5 + 15, GTR offset....on GTST guards...I think not.
So the question is, should I butcher the guards (which we are allowed to do this year) to fit the tyres.
This is a shot of the current set with a 30mm spacer (around the same offset as the 10.5). The wheel is loaded via a jack to running height.
  • Like 1
I'm interested to see how you go with the tyre monitor, what is it? How much etc?
Brother bought it as a birthday present. Not sure.
It's going to save waiting time in the pits between warm up laps and hot laps.
As generally, it go out and blast a 80% lap, come back into the pits. Make sure the pressure are good, then go out and hit up a fast lap.
The car sits around heat soaking while the pressures are checked.
So as long as we calibrate the pressure readings from the senors with a good external gauge, it should be useful.
Do you struggle for rear grip at the moment or is purely chasing more corner speed? In which case I'd be thinking the fronts would be the main concern?
Ah OK, well let us know how you go with it, and what tyre pressures you run etc.
I'd also be keen to hear what alignment settings you're using, though you can PM that if you're happy to share but don't want to over-share as some people don't.
Edited by ActionDan
front castor -7 deg
front camber -3 deg
front tow +0.8mm (ea)
rear camber -1.7 deg
rear tow -0.5 (ea)
The camber settings change a little as we lift the front and rear regularly to find balance for the conditions. This also changes the tow slightly, though not much with the R33 arms.
I haven't got any adjustable arms on the rear, so the standard camber bolts are pushed all the way to max positive.
Wheel alignment settings go together with the spring choice, sway-bar setup, rake etc.
  • Like 1
It makes me happy to see a car which gets driven properly - I love the re-shells in the first few pages.
Good on you for driving your car and not sitting it in the garage worrying it will get hurt - like seems to happen a lot these days.
Great driving too, maybe i'll meet you at the track one day.
You should be commended for the time of 104.9 on a cold day as the lap record for the V8 Utes is a 108.00
Whitline make a replacement adjustable front sway bar link KLC108 that is stronger than the standard unit. Here is a link to their site. http://www.whiteline.com.au/product_detail4.php?part_number=KLC108
You will butcher your rear quarters trying to get the 295's to fit. You could roll and flare out your quarters a good bit more than what they are ATM, but chasing THAT much the quarter will sink further up and scrubbing out under full load will haunt you I reckon. I've pushed mine to the limit without major work, ie heating, pin pulling a totally re shaping. No way I'd get them under my quarters.
Super awesome job on the 1.04 mate. it was good to meetyou and see this car in the metal too :)
How much power is the car making now? Im lucky to hit 185km at the kink. but it may also be that you're carrying a bit more speed through the last corner and can get on it eairlier.
Are you going to make a fibreglass spiltter/airdam?
Have to get the diff back together and the front splitter sorted this weekend.
I want to get out testing AD08R as soon as possible. Yoki have an event on the 3rd of August, so that is the aim.
http://www.yokohama.com.au/en/ADVAN-Motorsport/ADVAN-Neova-Cup/ADVAN-Track-Days.aspx
My brother has also been designing a rear diffuser.
It's actually built now, but no pics of the actually until it's all done :closedeyes:
  • Like 1
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
