however both Mafia and I aren't killing them through sensor positioning.. they're killing themselves... it's a known fact Innovate likes munching sensors.
The sensors are okay for me. Its the POS controller. Both of my LM2 units died. Sensors tested okay
Not suggesting that was the case at all, just clarifying where to position the sensor for maximum life and accuracy, you don't want it getting too hot and you don't want it getting wet from condensation.
I put mine where the cat would be. only been in use for 10-11 months. Was verified as accurate when new on dyno. Had car on dyno for touch up the other day and gauge was out by 0.8 afr. Showing leaner than actual. In fairness I haven't calibrated it in about 5-6 months, laziness. I will re calibrate it soon and see if it improves. Other than that, no issues but once it did get stuck in heating mode, lucky I realised and shut it down and it was fine after a restart. I have a suspicion that if I didn't catch it in time it would've fried itself.
Me and another tuner friend have been doing experiments with widebands to understand them better and see which perform the best.
Just remember that some are slow and some are fast.
ALM was meant to be the fastest, but I do not like the idea of overseas support. Techedge seem to be okay, but I need one to test.
We had 3 in a gas chamber - Autronic, Innovate LM2, and a ALM with a screen. The autronic was the best but doesn't support 4.9 sensors. (They are also expensive!) The others were using the 4.9 sensors.
When the AFRs go under 10, there are so fairly big discrepancies!
Also at leaner mixtures above 15:1
Be very mindful on picking a wideband. Personally, at this stage I think Techedge is the best, but I want to buy one and try it out.
So when you say that the controller cooks the sensor, do you literally mean that the heating control destroys the sensor? If its a heating logic issue, hopefully its something that can be remedied by a firmware update, rather than being a hardware issue.
Its the high current to heat the sensor that would be killing them. The sensor is connected and controlled through the gauge, so if it is outputting a large current output for too long, it all goes through the gauge, and high current = heat.
I installed an MTX-L to mine not long ago. So far so good. Quicker response than the AFM and was much easier to calibrate to the Link
I have an Innovate LC-2 connected to my Adaptronic and displayed via a custom Raspberri PI solution. The sensor is located in the recommended position about 30cm in front of my cat.
The LC-2 semi-regularly fails to acquire lock (the status LED stays flashing in warm-up mode) for an entire drive, or will occasionally find a lock after driving for 30-45 minutes.
Other times, when it's working properly, I can start the car from dead cold in the morning and it has acquired lock and showing me AFRs in about 10 seconds.
I would not buy one again, the reliability is poor. This kind of thing should work 100% of the time. I emailed Innovate to ask them about it and was ignored. No vendor support = why bother.
happen to share the raspberri display ? I want to replace my non working clock and put a screen there for the wb gauge, but they dont make anything commercial that fits.
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
    • Funny, but really not funny. Thank god (most) f the world has moved on since then
    • Lots of votes for driving onto a plank first; that is the quickest way I've found, 25mm is enough for my case but that will vary by car It also depends where you are going for. On the 32 I can get to the rear diff with my floor jack if I do that end first, and get it up on stands. Then I lift the front from either front tow hook as high as needed, also onto stands. Sometimes I need a small lift on the other tow hook to get it level enough If I do the front first I can't get to the rear diff because of the angle of the car Other options are getting to the front mount of the rear subframe from in front of the wheel (if only lifting one side, or just do both which is a bit of a pain compared to one lift from the diff), or also the gearbox cross member mount on the driver's side if you are  just trying to lift the driver's side. I This is the jack I use; it says 75mm clearance but of course that is only on the lower section so if you have to reach too far in like the diff you still get stuck. https://www.snapon-bluepoint.com.sg/category/Floor-Jacks/product/Floor-Jack,-2-Ton-Low-Profile
    • On the bright side, the weather will turn much nicer for working outside shortly....sounds like you might need to start on a neighbour's garden next
    • Ok so i will NEED to have this sensor anyway even with Nistune (or standalone ECU) https://justjap.com/products/genuine-nissan-boost-pressure-sensor-evap-control-system-fits-nissan-r34-skyline-c34-nm35-stagea-pnt30-x-trail-rb25det-vq25det-sr20vet?currency=AUD&srsltid=AfmBOoqfxX48bW9bEwH62orcNhtBfp7ekAL0C9Ca89ySFGUiBzXfXeze Is this the correct one? And this is only thing i need? No other "things" connected to the sensor or something? I do have the wiring.
