  • 1 month later...
  • 1 year later...
well if anyone of the NEO ppl were hesitating about doing it, there is no excuse now
http://www.ebay.com.au/itm/NEW-3-Wire-Universal-Oxygen-Sensor-O2-Easy-Fit-Kit-/120737660086?pt=AU_Car_Parts_Accessories&hash=item1c1c867cb6#ht_3120wt_1244
i bought the r33 one and cut the plug off (tried to be tricky and pull the pins out and swap them but they are slightly bigger in the r33 plug)
wish i had seen this, looks like the same sensor but cheaper again!
with the r33 sensor installed i got under 10l/100kms on the drive from tas-gold coast (yesterday)
Have any more Neo people run these? Looking to potentially buy one as my factory plug on both harness and O2 sensor have melted so would be much easier install with this kit
i was reading this topic the other day was through i would change mine in the stagea.
i change the sensor still dont know if it fix my fuel economy. driving around like normally
and it still used alot of fuel. i got a ngk one from ebay through...
That's not too hopeful. I think my current O2 sensor is ok and will be trying to do a direct wire in this arvo but if I have any problems was hoping to grab that ebay one for $40
  • 1 month later...
So I have never had any problems with fuel economy in my car but went and got it tuned today and the tuner actually turned the O2 sensor off because it was going spastic.
He showed me on the computer once the throttle is touched the O2 sensor went from nothing to max voltage straight away and just generally all over the place.
I tried to directly wire my O2 sensor in the other day could this be a stuff up with my wiring?
  • 9 months later...
tested my o2 sensor today, c34 stagea at warm idle to 3-4k revs i saw 0.3 -0.45 while parked. multimeter grounded in rocker cover and positive probe on black wire on o2 which is the thick brown wire on loom.
not sure what i'm looking for to confirm its stuffed other then it not alternating, unless i'm ment to be seeing more then 0.5v with no load parked ?
who can confirm?
^ thanks noted, just not sure if they can be half stuffed or it will work 100% and just not work at all if broke.
might just grab a universal 3 wire sensor from vulture for $40 as they are ment to be changed a bit like spark plugs , i assume the thread on the dump pipe is the same for r32-r34 gtst?
Edited by Dan_J
R33 and Neo are different
And then pay a little more and get an innovate wideband that has narrowband simulation for your ECU. Win win :)
Johnny are you using your WB as a NB simulator? If so how did you go about wiring it into the computer?
My NB has just blown so I going to use my techedge to simulate, it also has a function where I can alter the lean/ rich points so I can adjust stoich up or down for different fuels, or so I can target a leaner AFR
Wouldn't mind setting it up to hold 16:1 in closed loop, just to get better economy on cruise.
^ hey mate, I disconnected my narrowband in the engine bay and spliced the narrowband output from the innovate straight into the ECU harness.
There's no need to hook up the sensor ground and it worked really well. Not the first car I've done it to also, one thing I've noticed is that it "appears" to hit stoichiometric much quicker than factory narrowband O2s
Give it a crack you can't go wrong, in saying that I'm now running full closed loop fuel control with my wideband (running stand alone now woots)
I usually keep it stoich anything in vacuum up to atmospheric pressure (0.0psi), on cruise I'm a little cheeky and let it sit at 15.2
Best I've gotten out of 50L was 540km with the occasional squirt when I drove to Foster and back on 98 with the AC on most parts
So when in closed loop I get a hi reading of 15.23:1 and a low reading of 14.39:1 for and average of 14.8:1
Did a run to the gold coast on the weekend and got 8.9 L/100Km ~ United P100
Might have another play with it and try to get an average closer to 15:1
Edited by Missileman
^ great job on the economy side - on very load & cruising RPM you could even lean it a a touch close to 15.5 if you're after economy.. however drop back the timing a little so keep the cylinders happy.
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
