  • 7 months later...
  • 2 years later...
Can anyone confirm what voltage range I should be seeing in nissan consult for the O2 sensor from cold to warm.
Just wondering if mine is operating normally before buying a new one.
Mine was hovering at .26v got to .28 idling for 5mins approx. + bit of a rev is when it got to .28.
It settled back to .25v / .25v after a few more mins of idling.
I didn't check it again after 15min drive, will check again 2moz + water temps and post result.
Also with 188k on the clock, it well overdue for standard swap as part of servicing :).
300Km approx is all I manage out of a tank.
RB25NEO.
Cheers,
Pete
Edited by Stagea_Neo
fuel
Did some logging today. with engine already warmed up.
Water temp 69-73 deg c. range on each test.
10minute log / driving intervals.
O2 Sensor ranged from 0.01v up to 0.3v.
On the last test the O2 Sensor started reading 0.00v. for a little bit.
Will double check again tomorrow make sure it was'nt the consult logging software playing up.
Does this sound like normal operation of the O2?
Cheers,
Pete
No. Either the sensor is f**ked or your car is running very lean at idle. It should swing quickly between about 1 and 5v, going towards 5 when you floor it and 1 when you suddenly close the throttle.
Changing the sensor is the cheap and easy way to start trouble shooting....
  • Like 1
Thanks Duncan and Ben for the feedback.
Both of you commenting that volt range should swing back and forth, quickly at that.
Mine, volt range is not that far and far from quick.
I concur with your advice, it's f-cked :).
Time to order a new one. I have Kudos open on the other tab, they appear to be the cheapest, wallet within reach.
Some local parts stores wanted around $250-300 for nissan genuine.
Thanks again Pete :)
Fitted the new O2 sensor today.
Must say the car feels smoother/quieter on idle and through rev range.
Better pedal feel, don't have to press as hard to go : ).
Can see the comparison between old and new sensor below.
A lot more data in the second chart due to volt range covered and all the little fluctuations where 02 is functioning correctly.
I filled up the tank to the brim, will report back in a week or so on how many km's i got out of it.
Pete
Hi Ravi,
Yeah, forgot to mention that, I did that last week with some afm spray/cleaner.
Also about 2 years ago cleaned out the throttle body and inter-cooler.
No noticeable impact back then to economy either.
Cheers,
Pete
14 hours ago, admS15 said:
How many litres did it take to refill the tank?
Honestly didn't check that. Just filled it right up reset the trip meter, avoided any heavy foot driving.
Got to 276km and reaching empty line again, the low fuel light had flickered as went around a corner
so topped up again.
so topped up again.
You really need to take note and work out the litres per hundred to work out if the economy really is bad or you have an over enthusiastic low fuel light. For example in my skyline at the empty line I still have 25 litres in the tank which is more than 1/3 of its total capacity.
Actually you've jogged my memory with that last reply.  When I've had the low fuel light on and hitting bottom edge of low fuel line, I have to put in 55ltrs approx.
So I assume it ok, have approx 10ltrs left.
Well then, your still running too rich. Approx 20ltr/h. I noticed in an earlier post you said the car runs between 69-73 degrees. Its possible that your thermostat is stuck open and not allowing the engine to get to full temp which I would expect to be 85+. The ecu could still be in enrichment mode at the temps you're at. Just a thought.
  • Like 1
Good point, I might take it out and put it in a pot of boiling water and test it out for correct operation.
Also leads me to another snippet of info, I have one of those radiator caps similar to the nismo that operate
at 18.2 lbs (1.3 kg/cm). That shouldn't have any relevance should it?
No, that would just give it a higher pressure threshold and boiling point.
    • You can’t see much on the other side as the lcd is there I don’t think it’s the same as the m33 beside it as the markings on top is not the same was hoping someone had a good quality photo or if they just happened to have the unit in hand, quickly take the cover off and take a photo to clearly show the marking on top to identify the diode   the unit is currently with an electronics repair shop so I can’t take another photo at the moment hopefully they are smart enough to know if it’s a zener diode or not
    • I'd be very surprised if you can buy new OEM mats. But if you can, I want some too!  Do you have links to the variations you found? Also, where are you located? I found that Nengun is happy to list items to purchase but when you do buy them you'll get an email that it's actually discontinued. As far as I know the variations in floor mats are different colour schemes as well as automatic and manual having a slightly different shape. The automatic ones fit into a manual car without issues, but I think you'd have trouble fitting the other way around. I have photos that show the shape difference if you care. FWIW I bought sets of used floor mats in decent condition at yahoo auctions.
    • Hi 🙋‍♂️. Just bought my Unicorn but the interior need some minor work so it would match my expectations ;). I noticed it is hard to get used oem floor mats in good condition so i started to dig if there's any chance to buy set of new ones. I found two websites - nengun and amayama and it looks like one can still buy factory new floor mats in Japan, but thers a small issue. Some mats (i assume genuine, oem ones) are marked as G4900 and these are "discontinued". The ones you can buy are marked as G4911 but i have no idea if these are also oem, made by other producer or some lower quality replacements that looks entirely different. Can anyone help? 😃  P.s. there is also some strange indication - 0V005, 0V015 and 0V505. Any idea what does it mean? Would appreciate any help with this 🙏
    • Hi, Marek here 🙋‍♂️. I finally fulfilled my longtime dream - recently bought Stagea and now waiting for it to arrive in Poland. There's only few of these in my country, and one of the owners  recommended mi this forum as a source of all the info i'd need since now i own one  so here i am.
    • Version 1 aluminium airbox is.......not acceptable No pics as I "didn't like the look.....alot" Even after all my "CAD", and measurements, the leg near the fusebox just didn't sit right as it ended up about 10mm long and made the angle of the dangle look wrong, the height was a little short as well, meh, I wasn't that confident that Version 1 was going to be an instant winner I might give Version 2 another go, there's plenty of aluminium at work, but, after having in on and off a few times, and laying in the old OEM airbox without the new pod filter and MAF, there may be an option to modify the OEM air box and still use the Autoexe front cover and filter.... maybe This >  Needs to fit in here, but using the panel, and not the pod, the MAF will need to fit in the airbox though> I'm thinking as the old OEM box and Autoexe cover that is sitting in the shed is just sitting around doing nothing, and they are relatively abundant and cheap to replace if I mess it up and need another, it may well fit with some modifications to how the Autoexe brackets mounts to the rad support, and some dremiling to move it get in there, should give me some more room for activities, as I don't want to move the MAF and affect the tune Sealing the hole it requires to stick it in the air box is simple, a tight fit and some pinch weld will seal it up tight  I am calling this a later problem though
