  • 7 months later...
  • 2 years later...
Can anyone confirm what voltage range I should be seeing in nissan consult for the O2 sensor from cold to warm.
Just wondering if mine is operating normally before buying a new one.
Mine was hovering at .26v got to .28 idling for 5mins approx. + bit of a rev is when it got to .28.
It settled back to .25v / .25v after a few more mins of idling.
I didn't check it again after 15min drive, will check again 2moz + water temps and post result.
Also with 188k on the clock, it well overdue for standard swap as part of servicing :).
300Km approx is all I manage out of a tank.
RB25NEO.
Cheers,
Pete
Edited by Stagea_Neo
fuel
Did some logging today. with engine already warmed up.
Water temp 69-73 deg c. range on each test.
10minute log / driving intervals.
O2 Sensor ranged from 0.01v up to 0.3v.
On the last test the O2 Sensor started reading 0.00v. for a little bit.
Will double check again tomorrow make sure it was'nt the consult logging software playing up.
Does this sound like normal operation of the O2?
Cheers,
Pete
No. Either the sensor is f**ked or your car is running very lean at idle. It should swing quickly between about 1 and 5v, going towards 5 when you floor it and 1 when you suddenly close the throttle.
Changing the sensor is the cheap and easy way to start trouble shooting....
  • Like 1
Thanks Duncan and Ben for the feedback.
Both of you commenting that volt range should swing back and forth, quickly at that.
Mine, volt range is not that far and far from quick.
I concur with your advice, it's f-cked :).
Time to order a new one. I have Kudos open on the other tab, they appear to be the cheapest, wallet within reach.
Some local parts stores wanted around $250-300 for nissan genuine.
Thanks again Pete :)
Fitted the new O2 sensor today.
Must say the car feels smoother/quieter on idle and through rev range.
Better pedal feel, don't have to press as hard to go : ).
Can see the comparison between old and new sensor below.
A lot more data in the second chart due to volt range covered and all the little fluctuations where 02 is functioning correctly.
I filled up the tank to the brim, will report back in a week or so on how many km's i got out of it.
Pete
Hi Ravi,
Yeah, forgot to mention that, I did that last week with some afm spray/cleaner.
Also about 2 years ago cleaned out the throttle body and inter-cooler.
No noticeable impact back then to economy either.
Cheers,
Pete
14 hours ago, admS15 said:
How many litres did it take to refill the tank?
Honestly didn't check that. Just filled it right up reset the trip meter, avoided any heavy foot driving.
Got to 276km and reaching empty line again, the low fuel light had flickered as went around a corner
so topped up again.
so topped up again.
You really need to take note and work out the litres per hundred to work out if the economy really is bad or you have an over enthusiastic low fuel light. For example in my skyline at the empty line I still have 25 litres in the tank which is more than 1/3 of its total capacity.
Actually you've jogged my memory with that last reply.  When I've had the low fuel light on and hitting bottom edge of low fuel line, I have to put in 55ltrs approx.
So I assume it ok, have approx 10ltrs left.
Well then, your still running too rich. Approx 20ltr/h. I noticed in an earlier post you said the car runs between 69-73 degrees. Its possible that your thermostat is stuck open and not allowing the engine to get to full temp which I would expect to be 85+. The ecu could still be in enrichment mode at the temps you're at. Just a thought.
  • Like 1
Good point, I might take it out and put it in a pot of boiling water and test it out for correct operation.
Also leads me to another snippet of info, I have one of those radiator caps similar to the nismo that operate
at 18.2 lbs (1.3 kg/cm). That shouldn't have any relevance should it?
No, that would just give it a higher pressure threshold and boiling point.
    • Hi all. Been a while but things are moving along. I just have something that I am wondering about. Since I will use OEM turbo oil pumbing, I got myself a new bolt, the one that goes into the engine block oil feed. As I recall (and see visually) this bolt comes restricted with I think a 1.7mm hole? Not quite sure but it was something around that size. The turbos have 1mm restrictor bolts installed, as necessary due to ball bearings and my higher oil pressures. Can I now just use that OEM bolt with the 1.7mm hole in for the engine block or will this actually be too much oil flow restriction and I have to drill it out first? In my head it would make sense for the bolt to be at least 2mm wide as both turbos take "1mm of oil flow". Do let me know if my logic is flawed here, I just want to make sure I don't kill my turbo bearings with too little oil. Don't know if I can trust the saying I read somewhere that ball bearing turbos essentially only need an oil mist
    • There are several aftermarket options available, from not-too-painful moneyhttps://justjap.com/collections/driveshafts-bearings/products/d-max-reinforced-replacement-rear-driveshaft-set-fits-nissan-s13-s14-s15-r32-r33-r34-c35 and  https://justjap.com/products/crank-motorsport-billet-rear-axles-fits-nissan-skyline-r33-gts-t-r34-gt-t?srsltid=AfmBOorQk4xkGUa98kO7v2ePLUiNt-HRrM2AwWNw9mbSIVE1ujBVwY__, all the way up to The Driveshaft Shop https://driveshaftshop.com/skyline-cv-axles/
    • Yeah based on old XRC5964S specs, it looks to be roughly GTX3576R sized? But this 5964S compressor will flow 90lb airflow somewhat similar to the compressors in both the GTX3584RS or G35-1050.. I fully expected the 0.64 rear A/R to choke up top - seems way too small from typical convention - but these are seemingly beneficial over the prior 0.82 results.. Be interesting to see if he comments on the EFR question in that thread - he mentioned in a prior video that BW EFR's were the "cats pajamas 10 years ago", but by the sounds of things all his kits have been using Xona for quite a while now.
    • Yeah it’s still got the oem manual gearbox and clutch, only kinda mods are a blow off valve, coil overs, and a aftermarket intercooler. Also had it for about 2 months now with a lovely midnight purple paint on it.
    • Yeeeppp, been following a lot of the testing on the latest Xona stuff and there are some mental results.  He also went over 1000hp @ 4 hubs on his Mainline with a XRE6364S (63mm) which was also well into the 20psi range before 4000rpm on a 2.5. Crazy stuff. Fwiw the XRE5964S is basically the modern equivalent of their old HTA3582 - would drive nicely enough on an RB25 or 26, but proven capable of a huge amount of power if you want to spicy with rpm tho even at sane boost levels will make stout numbers
