Stretch lol, you get around the forum if I got it right :)
Rims are Advan RS-Ds 18X10 the tyres are 255/40 but have a set of Yokohama 265/35 AD08Rs ready to go on after I get the car back and use up the rubber on the car now :)
255/40s on an 18x10 rim :blink:
I too call you stretch
Stop mucking around and put those AD08rs on
haha, I thought the stretch was from a wasteland thread I was playing on :)
The tyres were on the car when I bought it and as the car has been living away from home most of the time I have not bothered. I want play a little bit when I run it in before I put the AD08Rs on.
I wanted 275/35 but they do not make a 275, just 265 then 285 ?
solution was simple.......should a got 285s :P
I know now :(
BJ said these 265s are the recommended size and I was not sure about the 285s but they do not last forever and if I like them, next time :)
what model you got mate?
R33's you can get away with fitting nice phat tyres but the R32's not so much
Yeah, gota call and could have got them for $220 as they got a lot in and trying to flog them :(
At first I was looking at going to 19x10.5 with the 285s but for whatever reason I changed my mind, cannot remember why, too much red maybe :)
When you are going through a learning curve with these cars it is not easy with anything you want to do, brakes and tyres are amongst the most confusing :/
But everything can become confusing and the more you read the worse it gets. In the end you have to make your mind up what you want from the car for yourself, then make the choice and hope it gets you what you want, it can be a costly choice if you get it wrong, lol
I totally understand what you mean. I've been there.
However you can only try to do what you think is right.
Sometimes you get it wrong but that's how you learn.
Talking to peeps in the business is sometimes the best thing instead of researching
After researching for ages I did speak to like mined blokes on SAU on just about everything I have done so far, then researched the info given. But they still have their preferences but a great guide to know what they have done has produced the type of results I wanted.
After I was sure what I had done to the car was not getting me the response I wanted I decided on the Nitto 3.2 stroker.
I kept everything from the earlier mods I did except the cams. I am sure I can get a lot more from the car but I do not need it :)
Probably went into over kill with the drive-train, but it all sounded soooooo GOOD :)
    • I've looked up the parts number (41011AL501). It's around $700 OEM. Usually our Infiniti G35 here in Canada have interchangeable parts with my Stagea but the parts number are not the same. I have looked around and it seems the JDM 2005 V35 Skyline (which is the same as our G35) has the same caliper but I cannot confirm. And I can't find a repair kit. The inner brake pads drags on the rotor, seems to be rusty piston. Thanks for the info by the way
    • This coupled with 6-9 speed autos with ridiculously short gearing is why these modern shitbox cars always seem so fast off the line. If it wasn't for those things, Raptors would not seem fast. The problem we have is there is a driveability gap between a more gentle take off and a wheelspinning sideways launch. The difference between ankle flex required to achieve one and ankle flex required to achieve the other is about 0.5°.
    • Yeah I think I'm also with the opposite here. It's 'hard to keep up with traffic' because in the real world I'm accelerating with 15% throttle and they are pinning it. It feels like I'm being an overt dickhead at anything above 15% throttle, so the car sounds like I'm being an overt dickhead to keep up with/get ahead of traffic when I'm really just trying to drive with traffic. There would be no issue 'keeping up with traffic' if we used the same level of throttle input/aggression to drive around. People really do just drive around with their foot nearly pinned in econoboxes.
    • To be fair it's the other way around. 300kw is boring in a modern Golf or BMW. They are so competent / well-engineered / devoid of emotion that you have to go stupid fast to feel anything. Whereas the <300kw RB still makes all the right noises and it feels good to drive. Can pull off at the lights with the turbo whooshing and the blow-off pssshing and feel like the coolest kid on the block. Just don't look to the side where you'll see the bored housewifes in their shitbox Yaris/Corolla/Camry that kept up because you didn't go fast at all
    • 300kW is so boring in a Skyline, you'll get spanked by someone's mum's Golf with Alibaba pipes, and an email tune.
