Horsepower sells cars, torque wins races!
Better tell that to the F1 manufactures...
Actually tell that to any race team that runs a turbo car that smashes larger displacement higher torque V8s. Do you remember Group A?
Or maybe you should grab a 6L turbo diesel and take it to the track and you will obliterate everything!
I personally love that phrase, makes it easy to pick out people with no clue
Edited by SimonR32
Lets compare apples here.
take for eg the current tube frame v8 supercars.
you have a choice, a 600hp SR20 or a 600hp 5L V8
but both still have a minimum weight of 1250kgs, same suspension same tyre etc.
which would you choose?
A SR20 as it would have more torque in the used rev range.
  • Like 1
And it would be geared so it would be in its sweet spot all the time, it would rev faster through its peak efficiency range and deliver torque to the wheels at a faster rate. therefor be much faster overall
Give me a rota spinning to 15000 rpm please
Edited by XGTRX
SR20, because it sounds better :ninja:
RB30 = Better rod stroke ratio.
RB26 = less registration issues here in VIC.
It it was without a custom crank id be going 30, if it was Regoed in VIC id be going 26.
There are lots of arguments for and against it, just as many for gear ratios, turbos etc which would make more changes at improving or ruining each engine sizes characteristics.
You need to look at it as a package, not just a engine package but including weight, gearing, tyres, track etc.
People like Berry successfully running a time attack RB30, lots of others running RB26's, some with stock cranks, some with strokers.
have seen what the Americans are doing with Diesel engines these days or have been living under a rock?
I'm starting to feel like I am wasting too much time on forums, but I had already thrown this together to ponder it visibly so I thought I'd throw this into the mix given that piston speeds/acceleration relative to rod length and stroke seems to come up in these conversations all the time - my maths may or may not be right here (looks close to legit to me haha) but this is more just to get an indicator of the sheer acceleration of the piston (at the pin) of the different factory RB layouts.
I have used this calculation to work out piston acceleration relative to crank angle (l = rod length, r = crank radius, A = crank angle, 0deg crank angle = TDC):
Piston acceleration to sustain equivalent rpm:
Piston acceleration to move equivalent swept volume:
I did it for my own interest so I figured I may as well share it as I know that some other people like to ponder on this kind of thing too. If anyone have a better (or more OCD) handle on physics/maths then feel free to correct or add to it - but again I will probably make myself relative scarce after this so I'm adding it before I lose the bits and pieces I put together.
Cheers.
Sound... I'll just leave this here:
K'n hell. How many million revs is that thing pulling as it crosses the line? Sounds awesome.
Edited by Cowboy1600
Le Mans :P
Where they are quite a bit slower than the other cars but way more fuel efficient so don't have to stop as often.
It's not the torque which makes them competitive.
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
