exactly what im aiming for... starlet is 1.3 engine also yes?
fabricator reckons itll pull crazy power..... im not so sure. engine is 300k old...
1331cc 321,000km engine.
Also it's my wife's car :)
so this weekend, we finished the cooler piping, and made a custom intake using a rip off hks filter from china!
car runs and runs well, although we have the bov completely disconected from the cooler piping as too stop the boost getting to the engine.
specs.
1275 300km engine
ga15 throttle body and afm
custom manifold
custom cooler piping
ford xr6 turbo intercooler
1 x t28 garrett gtr turbo.
future mods (to support e85)
gtst fuel pump.
cga3 top feed fuel rail, modded with vq25 injectors to fit cg13 intake mani.
exedy hd clutch
jun 3.4kg flywheel. (or 4kg cant rememebr)
hopefully get this done over the next two weekends.... tune is 6th of june. (if the nistune is ready in time)
the little micra that could, rajabdamn.
cant believe you got the fuel rail to work with those bits and pieces, usually they are a PITA to get different things to fit.
Where did you source the clutch and flywheel? did they double the budget of this build?
havent got the fuel rail to fit yet.
yes it will be fidlly, but its been done before, the only issue is clearance.....
i got the clutch and fly in a package with the hks/ohlins/tein suspension setup. and it cost just under a years rego.
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
