im pretty sure it was a space thing. we discussed log manifold, 4-1, but the end of the day we didnt have much space to fit athe turbo in, so we went with two, with a knife edge into the turbo.
Base tune confirmed with dmd,
natro powered, ga15 throttle body, 370cc injectors (thanks in advance scotty).
all to do is hook up bov, and swap fuel for e85 when i arrive. i might run the tank to empty on the way there... keep a spare bit of unleaded in the car just incase... dont really wanna be draining fuel in the middle of the street!
ha.
almost didnt pull anythin.
she had a fender bender last night, my own fault. looked down at the speedo to check my speed (as you do every 20 seconds in vic or face life in prison) literally half a sec later i looks up and theres a rajab damn ute sat in the middle of the highway.
fortunately i was doing about 30, but the roads where a little greasy, skidded into him at about 10kph. i got a smashed head light (which i ve fixed already) and a dented bonnet. ill pick a second hand one up when i can.
he had bent bumper and a slightly bent tail pipe. inb4 5k repair bill.
micra is off the road until i can replace the punctured tyre i have (prob caused the skid) and fit the better brake pads, fingers crossed its going back to scottys on sat night/sunday so i can install the hd clutch and jun fly.
shit night last, coupled with the fact my abs module blew on the hsv.
its time like this we all have when we doubt our builds/cars and consider selling them. wife was ace and said dont worry about it, was nothing you could have done.
nistune received my ecu this morning, so i should have that back with a base tune to run the 370cc injectors by the 30th.....
ha.
Oh that sux major Muslim grenades man.
Sounds only very cosmetic though and glad it was not any worse.
Keep it going man, most of us here want to see the Abbey Snot Rocket chop some ricers.
thanks guys. it no where near as bad as im making out.
still first accident (my fault) in 12 years. i was so angry at my self.
oh well! imma keep fighting the good fight.
scotty will be happy to know all i could think about during the accident was protect the intercooler and turbo! i had enough time to steer out of the way to the left, thats why it only copped the headlight. not full front on.
WTF? Damn shame Platts. Didn't bend the turbo did it?
read the above mate. nah made contact at about 10kph, guy came off his brakes for me as well. nice chap. he said he saw it happening but couldnt move because i lancer pulled out on him.
oh well.
lol wait till your motor blows...
i mean, fingers crossed itll hold strong whilst in your hands. glad to hear it wasnt a large accident.
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
