Perhaps it was fitted incorrectly. Too much heat in the crank or retaining bolts/screws not installed properly
Just a random guess seen as it sounds like you had a crank collar installed and thats where it broke. Better photos of the fatigue point?
https://www.sau.com.au/forums/topic/443843-broken-crank/#findComment-7299435
Very lucky made 480kw with some wheel spin and then lost 100kw and then started looking for the issue and found that. No other damage done lucky. Motor out today for another crank and some rings etc then back on the road in a few weeks
https://www.sau.com.au/forums/topic/443843-broken-crank/#findComment-7299535
Ill look at my wear guide later if I think of it but looks like it has fractured over a longer period of time. How long was this crank in use in this form for? And what Is the previous history of this particular part of the crank? (Heating to remove gear, crank collars on off etc)
https://www.sau.com.au/forums/topic/443843-broken-crank/#findComment-7299609
Looks like the woodruff key is at a slight angle and has moved inwards causing extra stress on the cranks snout.
Id say the balancer was moving on the crank and the vibration caused it to crack.
Ive heard similar about Ross dampners, that why we went with a ATI one from the start.
https://www.sau.com.au/forums/topic/443843-broken-crank/#findComment-7300121
    • That is surely the biggest gathering of Stageas in North America, ever!
    • Remember kids - if you can't afford to buy 2 GTRs......
    • I know people cry at the price of the Getrag 12-14k for a conversion now, but it really is a nice mid point. Not going to get change from 10k on a gearset installed.  $30k++ for sequential.   I know you run the risk of a damaged used one and parts are hard to get but as a street car gearbox its really hard to beat. If you enjoy a more traditional manual, its the choice no question.
    • Time to decide what’s more import, your power level or your budget because you’re going to struggle to keep both
    • Our Southern Highlands Cruise is proudly registered with “R U OK?” Day.  Sometimes the best way to check in on your mates is by getting out for a drive together. Sharing a common passion like cars creates the perfect space to chat, connect, and support each other.  A simple “R U OK?” can make all the difference. Let's enjoy the drive, the company, and look out for one another. PLEASE WEAR YELLOW FOR “R U OK?” DAY Sunday 14th September 2025 9:30AM Meeting Crossroads Homemaker Centre 10:00AM Cruise Departure Via Old Hume Hwy 11:45AM Arrival at Mittagong RSL Club Meet Location: Crossroads Homemaker Centre Final Destination: Mittagong RSL Club *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
