Thanks mate!
No specific plans to be honest. Just a few things I'd like to do.
So, after the trackday I went over everything again. Found my gearbox was making a nasty input bearing noise, so took it down to award. After a chat to Terry, he said it was nothing to worry about, and that the noise would probably drive out in a few hundred kms on the road. I suspect the ATF I was using in the box was too thin and not providing enough protection in high G areas, so I refilled it with Redline Shockproof light. Again, I can't complement the gearbox enough. People say they are weak, but this has had so many track days now, and looking back on the vids, a couple of times where it should have gone pop but hasn't! Driving style has a lot to do with it I think.
I've installed a power steering cooler, as I think the PS was getting pretty hot. I grabbed a small PWR auto tranny core from repco and plumbed it in, and ran a duct to it. Pics will be below. Pretty easy to setup, and not very expensive. It's just mounting it and finding the space!
I've got to get the dump pipe off, and it's got a couple of small cracks on one of the supports, they need a bit of weld.
I want to investigate water cooling for the wastegate. It has a tial 44mm on it, with the ports to water cool it. I want to do this mainly for reliability. But I'm not quite sure where to get and return the feeds to.
I also want to make up some deflectors for the front brakes, as they were getting pretty damm hot and glazed the pads. I never lost brakes, but it is clear that they can work better then what they were.
Finally, I might have my hands on some more slicks to try out after the Sydney 500. Should be a set of Yokos I can get my hands on. The Michelins have been epic, and are the Rolls Royce of slicks, but they are getting pretty worn now (have a look at the front right!).
  • Like 1
  • 2 months later...
You'll shit in an 11 if you can get it off the line.
Probably, my best 60ft was a 2.0
It's a bit of a pig to get off the line. This is on federal RSR 235/45/17 at 25psi. Doubt I'll take it again, I just don't want to smash the gearbox.
That brake squeal though
Because Racecar! Actually, I was bedding brakes in down the slow down area :D
  • Like 1
  • 1 month later...
Trackday put on by RTDC at SMSP south circuit. Had unfinished business since I was unable to take my place at the 2014 SAU trackday.
Had a little hiccup where some silicone intercooler pipe decided to burst due to heat and pressure, but fortunately some guys at the track helped me out with leads, and after a short drive, it was back in business without missing a session. Will make up some heat shielding to protect it for the future.
Rear tyres turned out to be pretty diabolical, so I couldn't even get full boost into her. Definitely due a new old set of slicks. In comparison, on full power out of the hairpin on the Brabham circuit day I could get power down pretty easily. On low boost it just burst into wheelspin.
Nevertheless, I got a PB (by 3.5 seconds no less!) of 1:04.1. Have no doubt on some fresher tyres that would drop into the threes.
  • Like 2
I heard the dyno ate your next pair of slicks, and the set from the F1GP will be mine... suckah.
Lol, no, someone who wanted to put on a "good show" for the cameras cause his ugly mug is gunna be on the telly ate up my new pair of slicks down to the belts!
I'll have my grubby little hands on something... ;)
  • Like 1
  • 3 months later...
Well, long time since updates, so away we go!
I noticed the rear pads were getting pretty hot, so I did something I should have done a long time ago. Cut the stone guards off it. I know, exciting right!
On to better shit.
I wanted to get it looking a bit tougher, and I went through a phase of looking for Type X bits for ages, but never bothered getting anything. I liked the look (everyone does compared to the earlier front end!!) and it gives me heaps more air to play with for ducting. Well, I found a OEM front bar, AND an OEM Lower lip for sale round my neck of the woods. Went for a drive, cash changed hands and boom; it was mine :)
Needed a bit of work, had some random holes in it, bit of a ding, and was silver, but had all the metal to go behind it. Well, something to work on!
So, I went to work - fibreglassed the holes, and a crack in the lower lip. Bogged up the dent, and filled the holes,
More to come in a bit :)
  • Like 1
So being an hugely experienced painter (having painted two bars, and a roof in my life...) I decided to do me own work. DIY mechanical is one thing, paint and panel is totally another!
Anyway, Bar and lip went into primer just fine
And then all these bits came along to make it look a bit more complete.
They're from JSAI Aero, and seem to be of decent quality, and test fitted ok.
Finally, a bit of a sneak peak ;)
Still have a fair bit more paint work to do, so another couple of weekends probably before its time to roll.
Got to get the electronics sorted for the new indicators too. The LEDs need resistors, and the wiring needs a tidy up.
  • Like 3
    • Why are people so insistent on making dirty water?!
    • Fark what are the changes of that snapping like that, clean. Nek minnit, custom radiator goes in, with built in oil cooler like those discontinued PWR ones from yesterdeacades ago
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
