Spotted a silver 33 gtst yesterday afternoon down smithfield fairfield way, he saw another skyline and thought it would be a good idea to limiter bash 1st to 2nd. Another red 33 gtst with fmic shortly after. A white 33 gtst on Cunningham st Fairfield between 6 & 7pm. A 33 4 door in doonside at 7ish.... A white 32 GTR parked up outside the ARDC shop at SMP most of yesterday.
Was that your 31 at smsp on Wednesday arvo doing the trackday???
The 2 door with gold VS XX wheels? Yeah that's mine. My gf and I were taking it out alternatively.
Did you have the red 180 with slicks? I didn't see it on track, just in the garage.
Edited by FordyR31
Yup, that's mine!
Hope you had a good trackday!
  • Like 1
White R32 with small lip rear spoiler at Bunnings Northmead. Young guy and girl got in and drove off.
And across the road at Super Cheap at The Junction, a white R34 with plates LLOOLL or similar.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
