Just saw a white and black R33/R34 in the RNP heading towards one of the beaches
It was Garie beach! shared a bit of a wave!
Also saw another white R33 south of Woolongong, had mad exhaust stains on the rear bumper! black as f**k!
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
