On 17/08/2017 at 8:51 PM, Old man 32 GTR said:
Spotted very clean white 32 GTR Oran Park Drive, plates are 111GTR,
Beautiful car
Saw it today at the same intersection. Bonnet up and hooking a tow rope. Poor guy
  • 3 weeks later...
  • 3 weeks later...
  • 4 weeks later...
  • 3 months later...
On 07/11/2017 at 7:54 PM, PranK said:
R33 Gtst turning onto Forest Way. I think he noticed my SAU stickers, I tried to give him a thumbs up.
Bora is a bit of a sleeper.
Haha!! This may have been me...!? =D
  • 2 months later...
Got accosted by an old time SAU'er at Shell in Warriewood. Didn't get a username, not sure if he's still on here. Was cool though, like the old days when you'd get noticed for wearing an SAU sticker. ?
  • 1 month later...
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
