Back together! Frigging runs GOOD too!
The only issue I saw anywhere was a bolt in the fan shroud. Very well could have flung around there and then got caught in shroud and was being hit by fan? No clue because sound is 100% gone.
Got everything checked and bled (wow it's easy to bleed with a swirl tank) and warmed up. Found out one part of my tune was setup wrong and off we went driving!
Quickly tuned in a mild pull (10 psi) after about 30 min of roughing it out. I AM LOVING THIS COMBO! It's going to be a nasty street car!!!
https://youtu.be/P5Txo9O4DXg
  • Like 2
Nothing changed at all. I'm telling you it had to be the bolt in the fan or something with an accessory. I didn't take pistons out. I did all this work with the engine in the car.
I stand behind my engine building still (my dad's a machinist, I learned a LONG time ago).
It does. The bottom port is Tee'd into the fittings behind the water pump (the one that circulates all the time no matter the thermostat position. The cap to the radiator is a fixed cap that allows fluid to overflow the radiator and head to the swirl pot. The three fittings in the hypertune head vent out the gases and into the swirl pot. When you rev the car at all it spins pretty violently...like over revving makes a vortex launch out of the top (which goes everywhere!)
Also I wanted to share that the Borg Warner Match bot program with the VE numbers I used HERE in post #9 look like they are reflecting my boost threshold PERFECTLY. Maybe missed the threshold by 100 rpms.
My low rpm matchbot prediction @ 21 psi: here
My high rpm matchbot prediction @ 21 psi: here
My low rpm matchbot prediction @ 10 psi: here
My high rpm matchbot prediction @ 10 psi: here
This is the screenshot of my latest log showing boost threshold. It's a punch from 2800 rpms in 3rd gear and just riding boost up.
5 psi by 3,000 rpms
9 psi by 3,600 rpms
Also added a simple excel graph of what the matchbot software says my flywheel horsepower should be in these cases.
little stuff today. Washed the car, fitted front air dam (forgot to get pics after), mounted battery permanent with the lightest battery hold down EVER, finished a few other odds and ends. Got the car cranking and idling pretty dang good, going to start boost tuning tomorrow (I hadn't read the haltech on boost tuning, I just turned it all off for now).
So tomorrow I'm hoping to build maps up to 14 psi boost (my goal anyway). Still likely going to limit to 7500 rpms and be weak on timing.
Went through haltech software and also setup a few other things I had overlooked (or had cut out for now). It was a pain getting the car to start up at all temp settings. They all kind of layer on each other and I was seeing WAY too much fuel on cranking (causing flooding when hot)
I'll be in touch more soon!!
Also I'm writing this here because I keep forgetting to do it.
adjust clutch
fix seatbelt latch
find reverse lights! (JDM apparently).
catch can vents (car hasn't puked a DROP of oil with the Mine's triple-baffle covers in it...of course I'm not on a road course yet).
Also 4wd light is on and feels like rear diff is loose. Gonna need a better one there.
my 4wd light was coming on cos the fluid in the boot was low., give it a bleed with new fluid and it might just fix the issue.
I completely bled it when I did the overhaul. Followed the "pull the white plug in kickpanel" and all that. Seems all good there. I keep forgetting to check the led light on the box when I finish driving.
  • Like 1
4WD works for a while then light comes on for TPS (21 blinks). I'm sure it has to do with the fact that I adjusted the tps to read about .5% on the TPS in the Haltech. I'll adjust it out in the tune to remove that 1% on the output and I will bet it will be fixed.
    • My experience with Rising Sun Exports Before agreeing to the sale I tried to do as much research as I could (obviously), his Facebook reviews are 98% and he goes Live at least once or twice a week. I contacted 2 people in the UK who had used him for their imports, both had positive feedback. His explanation and talk through of the import process was thorough, answering any query no matter how stupid it was. It felt as soon as the money was sent, communication dropped off. I asked for shipping updates every 2 weeks or so, not wanting to pester him, he never had any updates. I wasn't informed the car had been dropped off at the port, I only found out by his Facebook story. I asked for the photos taken at the port, knowing he would need some for insurance purposes. I received a few 5 second clips and that's it. When asked again, he said his staff had them. Weeks later I asked again, he tells me he doesn't have any, but does have 50 photos from the original advert. I never received them. I eventually got the documents sent via WhatsApp after I mentioned the port was requesting them. I purchased a CarVX report, to find out the vehicle is a Grade R with recorded accident damage, first recorded in 2017 when it was first auctioned. He never told me the grade, then again I didn't ask. His response was "Grade R means nothing, it wasn't chassis damage". Still, I would have liked to have been informed about it. Jon prides himself on being open and honest when it comes to inspecting cars, it's his main job doing so at the auctions for customers. When the vehicle arrived in the UK I noticed a few little cosmetic issues. It's a 21 year old car so it wasn't going to be mint condition. The side skirts are cracked on each corner and the sealant is failing. The front grill on the bonnet/hood isn't secured very well, mounting studs are missing. Both minor things, but again, it would have been nice to be told. During a Facebook Live walk around video of the vehicle, he mentioned it has a front Whiteline anti roll bar/sway bar. While on the inspection ramp, I noticed the stock item has been installed. When first questioned, his response was "the ARB? Switched? Since when, it never had them". Since sending video and photo evidence I've not received a response. I'm probably being over critical of the overall condition of an old car, but all I wanted was honesty (which he claims to have). I'm aware I wasn't his only customer, he's busy doing XYZ but other reviews praise him for great communication with regular updates and photos, I felt I didn't receive the same treatment.
    • I was able to get some underside photos while the car was on the ramp The suspension is all Altezza/IS200/IS300 so getting part's will hopefully be less of a headache
    • Welcome to my 2004 Toyota Mark ii IR-V Fortuna (series 2) With a 1JZ-GTE powerplant under the bonnet (hood) it'll give me plenty of scope for power upgrades. For those who aren't familiar with imports, the 1JZ-GTE is a 2.5L 6 cylinder VVTi engine with a single turbocharger. This has the factory R154 5 speed gearbox, along with a aftermarket 2 way LSD differential (brand unknown). Under the arches are a set of CST Zero 1 alloys, 18x9 +30 225/40 up front and 18x9.5 +15 265/35 on the rear. The car was quite low in Japan and there's evidence of the wheels catching the rolled arches/fenders. The tyre's aren't great so I'm in two minds whether to replace both or just the tyres and put up with the wider wheels on the rear. The car still uses stock brakes with the addition of some braided hoses. The exterior is stock with the exception of a BN Sports front bumper and a replacement Fortuna grill  Moving to the interior, the steering wheel has been replaced with a dished MOMO steering wheel (which will get swapped for my Momo Tuner for the time being) Defi Link Gauges are mounted above the climate controls and on the A pillar, the Oil Temp,Oil Pressure,Water Temp and Boost gauges should help with spirited and track driving  The stock seats have been replaced with some retrimmed Recaro bucket seats. Being a larger build these are a little snug, unfortunately the orange isn't for me so I'll look into replacing these down the line. Other modifications include a twin plate clutch, Blitz intercooler, Evolve alloy radiator, a stainless exhaust with decat, HKS EVC-S boost controller and coil overs
    • Apologies for the long read My R34 GTT was up for sale at the beginning of spring due to a few repairs creeping up. The strut tops needed replacing, roof and bonnet (hood) painting (yay for 3 stage pearl) and the underside stripped and treated. I sold the car which allowed me to be in a much better place financially. Leading up to the sale I was already thinking about the replacement. In an ideal world it needed to be a good all-rounder. Something I can mess around with, modify, do track days, do the school run, go on long drives etc.  Options included but not limited to... Laurel C35, Evo 8/9, Civic FD2, Impreza Hawkeye, Aristo and even an Audi S4 Avant (I've already got the Mazda 6 wagon). But there was always one car at the top of the list The Toyota Mark ii JZX110 I found an advert on a Facebook group for an example in Japan, from a seller called Jon at Rising Sun Exports. A few messages back and forth and Jon calls me from Yokohama one morning (or afternoon in his case). He briefly explained the import process, the costs involved and a repeat of the advert. After much deliberation, the price was agreed and the sale was locked in. I've never imported a vehicle so I jumped into the unknown head first. The money transfer was completed through wise.com (fees apply), very easy to use and the money was with him within a day or two.  The car suspension was raised for the vessel and the car dropped off at the port. It was 7 weeks later when the bill of lading was received and the freight invoice sent to me, followed by the export certificate a couple of days after (both digital copies) In the mean time the port had been in contact. I needed an agent to deal with the NOVA (notification of vehicle arrival) along with the tax/duty invoice, this was £75.00. The port also had a fee of £100, I'm guessing to cover the cost of the 10 day 'free storage' and for moving the car off the boat etc. They need a copy of the vehicle invoice, freight invoice and export certificate to allow the vehicle to pass through customs. The vessel arrived on Tuesday 5th August, the tax/duty invoice was generated and sent over. This is generally tax 20% and duty 10% of the vehicle value. Although the invoice came in at a higher amount than I had calculated. Once HMRC had received the payment the vehicle could be released from customs. I thought once the tax/duty was paid you could collect at any point, that's not the case. Your agent will need to book a collection slot, I requested Thursday 7th which was accepted, with a 9:00am slot allocated. It was a 5:00am start from Norfolk heading to Southampton. We eventually found the compound, upon presenting the bill of lading and some ID they released the car (they drove it out of the compound to the front ready for us to load up). The email from the port stated each slot had a 10 minute window, which seemed abit farfetched but the staff said it's not a strict rule. We were there for approx. 30-40 mins in total. A week prior to collecting I contacted my garage and explained the situation, I was able to get an inspection slot that afternoon. For the registration, DVLA require the car to be insured, for this I used a company called Adrian Flux who can insure the vehicle using the VIN number.
    • Hey guys, looking for these side skirts if anyone can help me out.
