How you finding your setup after a month mate?
Just normal driving so far, the Remsa pads have a touch more bite and are a bit dustier than the Intimas I had before but other than that there's no massive difference to be honest. I need to take the car out for a proper drive to see how they hold up in repeat heavy use.
Re the anti-squeal shims, the ones on my GTR have two thin plates which sort of clip together, whereas i notice in your pix there's only one. So, GTT owners, should he have one or two plates per pad?
You're right there are two shims, the inner ones (pictured) are full size and the outer ones are half size (diagonally cut). The photos above are of the inner shims only.
  • 1 month later...
Quick update, I was really enjoying my Remsa pads (rated 650 degrees) with DBA T3 Club Spec rotors at Sandown on Saturday.
I've got some issues with my brake booster but otherwise it's a great setup, no significant fade and no strange vibrations.
Mine were fine for 10k kms, now they are squealing also!
I think i'll just ignore it, I just tell myself it's a racecar.
try using brake shim grease, it's red in colour but I can't remember the name.. apply that to the shims & backside of the pad.. usually stops squealing for a while.. however once you hit the track it will squeal again..
If it's purely a street car, I believe you might be able to get away with it
It only sees the track every couple of months, I did grease the shims + pins etc. Not too bothered by it but I think I'll look into different pads next time I need some :)
Yeah I read several reports about A1RM squealing and went with the Remsas. They are quite dusty but I chose to take that over noise :)
A1RMs are also dusty! Maybe I'll look into Remsas as dust doesn't bother me in the slightest.
  • 1 year later...
Some more recent updates:
  1. Front Brake Disc Discolouration On The Inside
  2. Post Track Day Q's: Rotor Wear, Gearbox Oil, Ps Pump, Manifold Nuts
  3. Largest Brakes Under R34 Gtt Stock 17" Wheels?
About 15,000 km and three track days later I'm still running the original setup as per this thread, with minor updates:
  • Just had all rotors machined and fresh Remsa pads put on.
  • Half shims removed to address uneven pad wear (2), this seems to have improved pedal feel also
  • Heat shields removed on the inside (1), interesting to see if that cools down the rotors better on the track
I'm keen to add some ducting at some stage if I can find some decent backing plates that don't cost a fortune...
My A1RMs are silent after initial bed in and subsequent squealing (roughened the surface and bedded it in again).
Aren't the Resma pads rated lower then A1RM?
Yep A1RMs probably perform a touch better but have been reported to chew rotors.
Remsas are 650C temp rating, A1RM are 780C.
My a1rm's are also pretty quiet. They do start to squeal a bit after a track day but then settle down again after a few days of street driving. quite dusty though.
I've never seen anything as dusty as the Remsa, they start dusting if you as much as glance at them.. I'm fully expecting to find a little ants nest of dust next to the rims each morning.
  • 3 months later...
Does anyone know who might be able to supply cooling duct brackets to suit the R34 front hubs, to channel air into the inside centre of the disc to feed the veins? The OEM heat shields have been cut off.
I'm imagining something similar to this UAS Evo 6 kit - even a generic one might do:
I highly doubt the A1RM are rated up to 780 deg. C.. if so why the heck do they crumble like a cookie on the track and the likes of Intima SR and Project MU HC+ / HC800 pull up fine - and both are rated much lower.
I just finished off my first set of a1rm at Winton yesterday. Copped solid abuse for six sessions from start to finish, no cool down laps, last session was 10 laps and best lap of the day was on that lap. Pads where 50% at start of the day, didn't crumble but wore them right down. The rears where qfm hpx and they didn't like that treatment, they ended on just about metal on metal. In saying all that, at more demanding tracks like sandown, I don't think they will go too well. They are ok for the not so serious track car but it's the old saying, you get what you pay for and since I got another set for $60 for the front, I have put another set on the front. I measured the disc and compared to the measurement I took when they originally went on and the wear was 0.6mm. I thought that was ok. 4 track days, 1 set of pads, 1 set of tyres and 0.6mm of disc. Budget racing brah[emoji3]
  • Like 1
    • BRUH, one of the biggest mistakes of my life..... and i've had plenty ;[)
    • @Murray_Calavera iam just considering options 🙂 of course it is very expensive so that why i ask here 🙂  @joshuaho96 I looked at that GCG hybrid(i remember looking at it few weeks before) So this is "that" hybrid where i send them my turbo and they upgrade the inside to Garrett stuff and then they send it back. It cost around 1200-1300 USD which is FAR cheaper than the HKS and it is what iam looking for(i just do not have experience like this...to send something off to "upgrade" ) @tylink720 that is like 150 USD turbo no? 😄 I dont think i have the "ease on my mind" with this kind of turbo. I just put over 7000k USD to "LINK" up my engine...dont want to blow it up with cheap turbo 😄     EDIT: https://www.cj-motor.com/gcg-turbo-charger-for-nissan-rb20det-rb25det-high?srsltid=AfmBOooVeOZ6CZ6r1AIv5m-KPaa6BvudIPJTY8LW78khkd-gQlsaCht9 I looked at this and it seems ok? It is that CGC hybrid and it costs around 1250 USD (with back shipping). Do any of you have experience with this hybrid on NEO turbo? I quickly look thru the forum/web and it seems very good.
    • Echo the awesome sentiment 👍 Definitely a car worth saving. Looking forward to seeing updates as well.
    • Scenic roads, stunning skylines, and Chickos to finish it off! Join SAU NSW as we cruise through the Royal National Park and along Lawrence Hargrave Drive to Figtree! Sunday 26th October 2025 4:30PM Meeting Waterfall Station Parking 5:00PM Cruise Departure Royal National Park > Lawrence Hargrave Dr > Memorial Dr > Sid Parrish Park 6:15PM Arrival at Sid Parrish Park Figtree Meet Location: Waterfall Station Parking Final Destination: Sid Parrish Park RSVP: https://forms.gle/E4s5SiRKQfDdypky8 *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • It's funny, as Ive seen plenty of people use them in cheap builds on YT. And they actually go okay, even though a lot of other maxspeedingrods stuff is terrible. Those turbos seem reliable enough, the only part being, a good quality turbo that is "identical" to it, will out perform it day in and day out. In both a lower boost threshold, and the ability to flow more air at the same boost pressure. As a cheap cheap replacement, not a terrible choice. For cheap and shouldn't blow in a day, not terrible (like other eBay/Temu turbos) for low cost and still decent performance, that's where the question comes in to play from the results I've seen. I'd actually find it hilarious to buy one, and strap it to a paddock basher or some other cheap as POS originally NA car, and send it to the moon!
