How you finding your setup after a month mate?
Just normal driving so far, the Remsa pads have a touch more bite and are a bit dustier than the Intimas I had before but other than that there's no massive difference to be honest. I need to take the car out for a proper drive to see how they hold up in repeat heavy use.
Re the anti-squeal shims, the ones on my GTR have two thin plates which sort of clip together, whereas i notice in your pix there's only one. So, GTT owners, should he have one or two plates per pad?
You're right there are two shims, the inner ones (pictured) are full size and the outer ones are half size (diagonally cut). The photos above are of the inner shims only.
  • 1 month later...
Quick update, I was really enjoying my Remsa pads (rated 650 degrees) with DBA T3 Club Spec rotors at Sandown on Saturday.
I've got some issues with my brake booster but otherwise it's a great setup, no significant fade and no strange vibrations.
Mine were fine for 10k kms, now they are squealing also!
I think i'll just ignore it, I just tell myself it's a racecar.
try using brake shim grease, it's red in colour but I can't remember the name.. apply that to the shims & backside of the pad.. usually stops squealing for a while.. however once you hit the track it will squeal again..
If it's purely a street car, I believe you might be able to get away with it
It only sees the track every couple of months, I did grease the shims + pins etc. Not too bothered by it but I think I'll look into different pads next time I need some :)
Yeah I read several reports about A1RM squealing and went with the Remsas. They are quite dusty but I chose to take that over noise :)
A1RMs are also dusty! Maybe I'll look into Remsas as dust doesn't bother me in the slightest.
  • 1 year later...
Some more recent updates:
  1. Front Brake Disc Discolouration On The Inside
  2. Post Track Day Q's: Rotor Wear, Gearbox Oil, Ps Pump, Manifold Nuts
  3. Largest Brakes Under R34 Gtt Stock 17" Wheels?
About 15,000 km and three track days later I'm still running the original setup as per this thread, with minor updates:
  • Just had all rotors machined and fresh Remsa pads put on.
  • Half shims removed to address uneven pad wear (2), this seems to have improved pedal feel also
  • Heat shields removed on the inside (1), interesting to see if that cools down the rotors better on the track
I'm keen to add some ducting at some stage if I can find some decent backing plates that don't cost a fortune...
My A1RMs are silent after initial bed in and subsequent squealing (roughened the surface and bedded it in again).
Aren't the Resma pads rated lower then A1RM?
Yep A1RMs probably perform a touch better but have been reported to chew rotors.
Remsas are 650C temp rating, A1RM are 780C.
My a1rm's are also pretty quiet. They do start to squeal a bit after a track day but then settle down again after a few days of street driving. quite dusty though.
I've never seen anything as dusty as the Remsa, they start dusting if you as much as glance at them.. I'm fully expecting to find a little ants nest of dust next to the rims each morning.
  • 3 months later...
Does anyone know who might be able to supply cooling duct brackets to suit the R34 front hubs, to channel air into the inside centre of the disc to feed the veins? The OEM heat shields have been cut off.
I'm imagining something similar to this UAS Evo 6 kit - even a generic one might do:
I highly doubt the A1RM are rated up to 780 deg. C.. if so why the heck do they crumble like a cookie on the track and the likes of Intima SR and Project MU HC+ / HC800 pull up fine - and both are rated much lower.
I just finished off my first set of a1rm at Winton yesterday. Copped solid abuse for six sessions from start to finish, no cool down laps, last session was 10 laps and best lap of the day was on that lap. Pads where 50% at start of the day, didn't crumble but wore them right down. The rears where qfm hpx and they didn't like that treatment, they ended on just about metal on metal. In saying all that, at more demanding tracks like sandown, I don't think they will go too well. They are ok for the not so serious track car but it's the old saying, you get what you pay for and since I got another set for $60 for the front, I have put another set on the front. I measured the disc and compared to the measurement I took when they originally went on and the wear was 0.6mm. I thought that was ok. 4 track days, 1 set of pads, 1 set of tyres and 0.6mm of disc. Budget racing brah[emoji3]
  • Like 1
    • GCG is a good company, they're a major distributor for Garrett in Japan as well.
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
