4 hours ago, Dose Pipe Sutututu said:
I highly doubt the A1RM are rated up to 780 deg. C.. if so why the heck do they crumble like a cookie on the track and the likes of Intima SR and Project MU HC+ / HC800 pull up fine - and both are rated much lower.
The 780C came from this QFM page: http://qfm.com.au/page/6/Performance_Range
3 hours ago, admS15 said:
I just finished off my first set of a1rm at Winton yesterday. Copped solid abuse for six sessions from start to finish, no cool down laps, last session was 10 laps and best lap of the day was on that lap. Pads where 50% at start of the day, didn't crumble but wore them right down. The rears where qfm hpx and they didn't like that treatment, they ended on just about metal on metal. In saying all that, at more demanding tracks like sandown, I don't think they will go too well. They are ok for the not so serious track car but it's the old saying, you get what you pay for and since I got another set for $60 for the front, I have put another set on the front. I measured the disc and compared to the measurement I took when they originally went on and the wear was 0.6mm. I thought that was ok. 4 track days, 1 set of pads, 1 set of tyres and 0.6mm of disc. Budget racing brahemoji3.png
Thanks, good to know!
I need something that can take the Sandown 200->90km/h punishment down the front straight repeatedly, and I'm tossing between Intima SR or Forza FP3 as a step up from Remsa.
I got some R33 GT-R OEM brake ducts off a forum member (thanks!).
I went to measure them tonight and they're pretty hefty, the height is 50mm. I'm already height challenged in the front so mounting these beneath the undertray/liner is most likely not an option..
Does anyone run similar brake ducts in their R34 (GTT or GTR)? Is there any chance to squeeze these above the liner somehow?
Otherwise I might have to set up vents and soft ducting from the fog light openings. It's a series 1 front bar.
  • Like 2
  • 4 weeks later...
I just finished fabricating some front brake air guides over the weekend, made out of 0.9mm galvanised steel. The design is largely inspired by the UAS ones (thanks dan.1337 for the photo and link!) but also looking at the OEM GT-R V-Spec ones. The most time consuming part was testing a number of prototypes at varying levels of lock and suspension compression to ensure that everything clears at all times.
What do you guys reckon, should I make some for the rears too? I cooked my 650C pads in all corners last track day (granted not enough cool down laps). I have since had the rear heat shields removed too, which hopefully cools rotors more evenly but will probably heat up drive shafts/boots/suspension components more now...
Also the R33 front brake ducts won't clear at my ride height so I'm thinking of adding just some rubber 'fins' on the undertray to channel more air towards the air guides. Might be an overkill.
Here's some photos of the front brake air guides (car jacked up, suspension fully expanded), yet to be painted:
Front left with steering straight
Front left with full lock in
Front left with full lock out
Rear right with no heat shield
The prospective air guide would follow the curve of the lower control arm edge I imagine and feed into the small gap between inner edge of the rotor and the handbrake assembly?
  • Like 3
8 minutes ago, admS15 said:
Thanks man! A lot of the ones you see around tend to cool the disc face, I like the UAS style as it feeds inside the disc to allow the vanes to vent more effectively.
Also quick tip for anyone wanting to give this a go: the jigsaw with a metal cutting blade was a revelation after initial struggles with tin snips...
that's really cool!
did you just use those U bracket things (those brackets to hold up conduit) to attach it?
Lol :)
Yes three mounting points: 8mm bolt at the hot end, widened 25mm conduit bracket in the middle, wide cable tie in front. I'll try to get a photo from the back later.
Here's how the front right looks from the inside, you can see the three mounting points:
6 hours ago, mr skidz said:
We need to make a mould and carbon fibre those things they'll sell like hotcakes
Or maybe someone can scan them and produce them on a 3D printer.
Could work but probably over-engineered :) It's just a flat sheet cut up to right dimensions and bent. I might look at doing a template if these work at Sandown next week ;)
Both front and rear air guides went well at Sandown today, with no ill effects. No brake fade but I didn't get any good runs in either as I had to nurse the car, pretty sure the head gasket is gone :/
Here's the rear left mounted:
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
