Honestly with that much power in mind, just get a cross flow and a forward facing plenum.
It'll make life a lot nicer when it comes to working on the car and its a lot simpler (less joins, fewer points of failure)
I tell you know, if you're going to be getting 380rwkw out of a GTST, it's going to be FAR from legal and you'll have more than a few headaches with police. Effectively turning your car and $10,000 worth of mods into a garage queen.
Just get a crossflow and get Scotty_NM35 to fab you up a pipe which can bend around the bottom of the radiator and pop up into the engine bay... No holes needed.
A big high flow turbo + E85 + Blitz return flow + factory airbox would keep you under the radar.
In the end police will always be able to find an ECU or injectors or boost controller if they want to look for them, which means anything over 170rwkw has the potential to get you found out. It's all about hiding it as well as you can. If you can keep the engine bay looking stock they won't have reason to look much further. I'd argue that any forward facing plenum is grounds to scrutinise the engine bay, versus a cooler that uses the factory piping.
But some people say blitz return flow cooler won't handle 380rkws .can only handle 250rwks
Some people don't know
I'm doing 275 with mine on a conservative dyno and I don't think it's at its limits.
If you are in Vic, keep it all looking as stock as possible. You can still make the power using ethanol as a fuel instead of dino 98.
Either a good return flow or custom piping cross flow will do the job, no need for holes to be cut. ;)
How can cops find out what ecu or injectors u got???
also i have a blitz return flow for sale if your interested :)
If cops that moody, they'll tear your car apart.
don't they need a warrant or something for that? they not really allowed to pull out the interior trims are they?
Dunno what rock you've been living in, but cops are known to take kick panel out to see what ecu the car has and some cops know what colour injector caps of cars.
Welcome to Victoria.
Plus some cops doesn't even do that and decide to send you a EPA letter and let EPA do the work.
They carry portable tool kits
Screwdriver to pop open / destroy your kick panel and look for ECU
Injectors are pretty obvious if you know the engine and certain Knox people know the standard RB25 colour is dark red/maroon
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
    • Thanks for the quick reply. To be clear, when you say turbo shuffle do you mean turbo flutter "stustustu" or referring to something else? I had thought they were the same thing. When I wrote the post my intention was to say it wasn't a flutter/compression surge sound. My understanding was that a flutter sound would be occurring when throttle is released, whereas I can keep the throttle in the same position for this noise
