Get in the Tiida and just rock up.
Take the keys off Jimbo and rip a launch up the street.
Wish it was that easy, after I get the OK I have to get the girls looked after and book a flight to Sydney
You are one sick puppy Paul :spank: nice butt :3some:
I don't think so, said it was the first run ??
It is just about impossible to speak to anyone that knows what is going on and only get info second hand ?
Sure will be glad when it is over :)
I am sure they feel the same way :)
I am not the best at reading graphs but next week I will know how it feels when I have my fat arse on the seat and a 350 Klm drive home, going to use the old Highway to give it some work away from the Freeway :)
I hope there is a heap better graph once the final tune is done :/
Hi Mick-o , I asked that question before and I think they said they cannot do it with their Dyno program, I would think you could make the program do what you want it to ??
Needs more boost!!
Good to see it going ( I too cannot understand why some people show mph instead of rpm).
My guess is the final figure will be between 400 and 500 awkw - anywhere in that range should do!
  • Like 1
Needs more boost!!
Hi Bob, just want it finished and hopefully give me the responsive results I have worked to get, well paid to get :)
Looking at 400awkw ish on 98 pump. maybe 450 with E85.
Does not matter at this stage, I just want my car back :)
I'd say 5 months is probably ahead of time on a build like this by a professional workshop....
There will be a month or more of a bit of back and forth once delivered to sort any small issues, run in and re-tune etc.
... it's better not to hope for a number on a page, regardless of what the car makes on that dyno on that day on that fuel your allways just a little dissaponted.
... these days I just rock up and go 'it make what it makes'
Cheers
J.
  • Like 1
    • Hi, i’m making a rb25det coil loom for Vag short coil. Can anybody tell me which Ecu signal wire belong to coil number 1 and 2,3,4,5,6? The connecting switch in above pic is 8 wire i think white is for +12v and black for earth.
    • Was there ever a model of the Stagea m35 that didnt have a badge on the grill? I thought I saw that somewhere, some aero edition or something? I cant find it again? davemoto
    • Its a 2002 vr-x four VQ25DET, silver. Coil overs, lowered, polished alloys and sport exhaust. Bit of a project, was sitting in a shed for a while but runs and drives great.
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
