This isn't a group buy in the traditional 'get an existing product cheaper' sense, but more a 'please please please let us own these arms' - as such, I don't have a minimum run time (sooner the better?) or delivery information. So please, bear with me.
GKTech recently put up their design for an R32 GTR/Z32 front upper control arm based on the Group A design. Unfortunately, he has shelved the project due to it being prohibitively expensive - so I want to get some arms raised to get these on the market.
The issue with most camber arms flogging out bearings is that the inner and outer bearings are locked parallel to each other - however when you add caster, the bolts are no longer equal. To stop the bearings getting flogged out, the arm needs to be able to rotate.
The only arm currently on the market is made by Unique Autosports. UAS's design has the rotation, however is very expensive ($595).
Speaking with Greg at GKTech, in order to get the ball rolling he will need a minimum of 30 sets @ $399. Who's keen?
Reported this on Z32 forum as z32 has all kinds of issues with FUCA's.
http://www.aus300zx.com/forum/showthread.php?p=1426396#post1426396
Survey says, these are not suitable for Z32.
  • 1 year later...
  • 2 months later...
  • 2 months later...
I've been keeping in touch with Greg at GK Tech and he emailed a week or two ago saying they are currently in production..
I'd say there is a good chance they will be ready before year end :banana:
As for the group buy/pricing no idea sorry
  • 4 months later...
  • 1 month later...
  • 3 weeks later...
  • 4 weeks later...
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
