haydenrowe Posted February 1, 2015 Share Posted February 1, 2015 Hey guys & girls! Chasing a basemap or any map really for a r32/33 gtst and a wolf3d V4 to get my engine conversion running Link to comment https://www.sau.com.au/forums/topic/453376-wolf3d-v4-basemap-for-r3233gtst/ Share on other sites More sharing options...
GTSBoy Posted February 1, 2015 Share Posted February 1, 2015 Which one? One is RB20, other is 25. Link to comment https://www.sau.com.au/forums/topic/453376-wolf3d-v4-basemap-for-r3233gtst/#findComment-7470975 Share on other sites More sharing options...
haydenrowe Posted February 1, 2015 Author Share Posted February 1, 2015 Its an RB20 but either will work. Apparently the basetune from wolf is the same? Link to comment https://www.sau.com.au/forums/topic/453376-wolf3d-v4-basemap-for-r3233gtst/#findComment-7470977 Share on other sites More sharing options...
GTSBoy Posted February 1, 2015 Share Posted February 1, 2015 Can't imagine that they are the same tune file. The AFMs have similar capacity, but the injectors are totally different (25 are 370cc, 20 are 270cc) and there are differences in how the TPS works and so on. So you really want a 20 file. Have you thought about asking AEMS or (whoever they are)? Link to comment https://www.sau.com.au/forums/topic/453376-wolf3d-v4-basemap-for-r3233gtst/#findComment-7470983 Share on other sites More sharing options...
haydenrowe Posted February 1, 2015 Author Share Posted February 1, 2015 I have emailed them and they have indicated they will get back To me. Just thought I'd see if anyone had one that could work ad I'd like to get it running. From what I can see the p&p units come with the same base setup for the two models. Link to comment https://www.sau.com.au/forums/topic/453376-wolf3d-v4-basemap-for-r3233gtst/#findComment-7470989 Share on other sites More sharing options...
89CAL Posted February 1, 2015 Share Posted February 1, 2015 They are probably like the link ones. Some of the inputs/outputs are different and had to be changed on my 25 I would suggest asking for a map from whatever car you have to make it easier 1 Link to comment https://www.sau.com.au/forums/topic/453376-wolf3d-v4-basemap-for-r3233gtst/#findComment-7471077 Share on other sites More sharing options...
KiwiRS4T Posted February 1, 2015 Share Posted February 1, 2015 No such thing as Plug and Play really - its not a Nintendo. Yes they plug in. Then you have to add maybe a temp sensor, MAP sensor, Mac valve and then tune. Link to comment https://www.sau.com.au/forums/topic/453376-wolf3d-v4-basemap-for-r3233gtst/#findComment-7471098 Share on other sites More sharing options...
haydenrowe Posted February 1, 2015 Author Share Posted February 1, 2015 Not if you use the standard AFM... Point being, they don't require wiring modifications or extensive setup to get the car to run Link to comment https://www.sau.com.au/forums/topic/453376-wolf3d-v4-basemap-for-r3233gtst/#findComment-7471133 Share on other sites More sharing options...
haydenrowe Posted February 1, 2015 Author Share Posted February 1, 2015 Have asked, still waiting. Obviously don't work on weekends so is difficult. I'll call tomorrow and see if I can get one. Was just exploring options to see if someone had one today Link to comment https://www.sau.com.au/forums/topic/453376-wolf3d-v4-basemap-for-r3233gtst/#findComment-7471135 Share on other sites More sharing options...
Scott Black Posted February 1, 2015 Share Posted February 1, 2015 is it ve based or still pulsewidth ms for fuel tables, if its ve based, enter all the crap you need into the settings, then just put 100 across the entire map and 15degrees timing and it should be able to make it start from that. Link to comment https://www.sau.com.au/forums/topic/453376-wolf3d-v4-basemap-for-r3233gtst/#findComment-7471172 Share on other sites More sharing options...
Dasmbo Posted February 25, 2015 Share Posted February 25, 2015 Drop me you email address and ill send you my old r33 rb25 maps Link to comment https://www.sau.com.au/forums/topic/453376-wolf3d-v4-basemap-for-r3233gtst/#findComment-7487055 Share on other sites More sharing options...
