3.5" is perfectly fine, just get the 3" section redone in 3.5" or atleast the bit from where the wastegate joins the main exhaust to where it changes to 3.5"
get the Venom 5" cat in between ?
Had a look at the Venom and they seem pretty tough
It's only the body on the 5" Venom that is 5"s, the inlet and outlet are 3"-3.5"or 4"
So I think you should get the one with 3.5" in and out lets and change the 3" part of your exhaust to 3.5"
Or if you are feeling rich or don't think you can take it with you get a new full 4" system
  • Like 1
Understand, I think I will go with the Venom 500 series, 5" body, with the 3.5" inlet / outlet and have the rest modified to suit. I guess I can still use my high flow muffler :)
One question ?
what difference would a 4" exhaust system with a 5" Venom body ? hate dumping all the new shit if the difference is not noticeable :(
Pete you're on the right track, maybe try to find out what the cat actually is and also the reason for the diam reduction before you drop more coin. The only way to really id a restriction is to run it up on a dyno and back to back after removing individual parts. Did this on mine and it was interesting, I'm sure Jez could do it for you.
If you're concerned re noise, 4" will be good for grunt but probably also louder.
Thanks mate, I do not need it any louder.
So if I can get rid of the 3" sections and use the 5" Venom cat , it will keep it quieter and legalish
At 400-450rwkw, not a great lot, certainly not enough to justify the cost
If you had a full 3" i would suggest a full 4" for your setup just incase more powah is looked for in future but since you already have 3.5" just finish it off and it will work well for your current turbo
IIRC the 100cell 5" venom core will flow close enough 4" pipe worth of flow
My 4" system is quieter then the 80mm jap cat back i took off
Scooby already suggested but if you do back to back runs on the dyno you will see how much that 3" cat is actually restricting you. Definitely too small for the power you're chasing and probably not worth going to a full 4" system as mentioned so just throw in a new cat that is bigger and better and modify some flanges to suit so it can all bolt up nicely.
The question is, why the f**k did CRD put a 3inch restriction on this 3.2L engine with that turbo
I would have assumed they knew that it needed a decent exhaust to make power and response..
Hey CRD if your reading this, show me a graph where exhaust restriction with a turbo actually helps with response or power ya clowns
Or are you just playing dumb so you can charge pete for another retune
  • Like 1
Its pretty obvious when a company is going down the shit shute, Pete is just one percent of their business.
don't give them any more money, if the problems do not get sorted, seek legal advice????
be methodical and not emotional!
In these situations it is only fair to give a company a chance to fix any problems, then if it is not done properly it is time to do whatever is needed to have the situation rectified.
I do not have to be happy with everything and I have spoken to them about it and they asked me to bring the car in so they can sort it out, they cannot do more than that. So I will wait until it is all finished before I start throwing stones . The distance is my problem but it is a pain :)
I will be asking about the exhaust today and see what they say I should do.
All of the other work seems great, drive train works a treat and I can see with a few tweaks I should be happy with the car :)
Some of the prices seemed high to me, especially the Tune and I paid over the quote but I wonder if I would be whinging if it turned out better, probably :)
On this engine turbo is the restriction!
why is that, it is good for over 700HP and it is nowhere near that ???
I think he's alluding to the fact that if you had a bigger turbo you could make 1200hp.
And yes 3.5in will do 600awkw so should be fine for you.
  • Like 1
1200HP,haha, I am just after a strong , reliable street car and if I sort the exhaust out I think they (somebody) will be able to tune it to how I want it .
Went for a 400 klm run today and in my area there is some nice road to get a feeling for the mods on my drive train, went to have my AD08Rs on and the trip home was fun :)
But it needs to be re tuned badly !
Still rich as, and does not like to be revved , but even as is , it is a fun ride :)
Cannot wait to get this shit over with and see what I finally end up with?????
    • I'm back from the dyno - again! I went looking for someone who knew LS's and had a roller dyno, to see how it shaped up compared to everything else and confirm the powerband really is peaking where Mr Mamo says it should. TLDR: The dyno result I got this time definitely had the shape of how it feels on the road and finally 'makes sense'. Also we had a bit more time to play with timing on the dyno, it turns out the common practice in LS is to lower the timing around peak torque and restore it to max after. So given a car was on the dyno and mostly dialled in already, it was time for tweaking. Luis at APS is definitely knowledgable when it came to this and had overlays ready to go and was happy to share. If you map out your cylinder airmass you start seeing graphs that look a LOT like the engine's torque curve. The good thing also is if you map out your timing curve when you're avoiding knock... this curve very much looks like the inverse of the airmass curve. The result? Well it's another 10.7kw/14hp kw from where I drove it in at. Pretty much everywhere, too. As to how much this car actually makes in Hub Dyno numbers, American Dyno numbers, or Mainline dyno numbers, I say I don't know and it's gone up ~25kw since I started tinkering lol. It IS interesting how the shorter ratio gears I have aren't scaled right on this dyno - 6840RPM is 199KMH, not 175KMH. I have also seen other printouts here with cars with less mods at much higher "kmh" for their RPM due Commodores having 3.45's or longer (!) rear diff ratios maxing out 4th gear which is the 1:1 gear on the T56. Does this matter? No, not really. The real answer is go to the strip and see what it traps, but: I guess I should have gone last Sunday...
    • 310mm rotors will be avilable from Australia, Japan, and probably a few other places. Nothing for the front can be put on the back.
    • The filter only filters down to a specific size. Add to that, the filter is AFTER the pump. So it means everything starts breaking your pump even if its being filtered out.
    • Just like in being 14mm too small (296mm) makes it not fit, being 14mm too big (324mm) it also won't fit. You want to find the correct rotor.
    • @GTSBoy Ok so that was the shops problem...they showed R33 rotors on R34 page and i did not know 296 do not fit(and are for R33) Yes i bought "kit" with rotors and pads. Pads are ok(i have GTT calipers front and rear). They have some 324mm but no 310mm. So i dont know if they would fit. I have 17inch LMGT4s So another question. Can i fit those in the rear or they are just "too" big for that?
