I wouldn't know Jez from a bar of soap, but if he is using shit products like cheap single layer gaskets on a high end build like this I thought I would comment.
......sorry I thought this was a forum?
Hi Chris, cars on the Dyno line up , so all good . Offered him $10 to push it up the line, something was mentioned about tight arse :O
I have no idea why the gasket was on the mani , maybe to protect the surface , he uses Silicone for this job, I did not know you could use Silicone under such extreme heat :blush: That RTV seems to be able to handle :devil:
  • Like 1
Once you feel the E85 tune, i predict you'll be storing it up in 200L drums, even a 50% mix is probably heaps better for your setup than 98...
Paul has told me this a 1000 times, I will have to buy a trailer and pop a Tbar on the Tiida :)
It was mentioned that the E85 would work great on the setup, I guess if it was local it would be a no brainer as it also seems better for the engine.
  • Like 1
It's going to strip a lot of crap from your fuel tank and lines. If it was dirty. And then everything will be squeaky clean.
RTV is the bomb period. Resists oils coolants and heat. Used it on my mates manifold. She was sweet.
He gave the car a run to check for leaks today and all good , so I can stop driving you blokes nuts pretty soon on this thread before the 100, then I can say :quit ur:LOL!
But I am getting nervous about the results, I do not need a lot more and just want it to run sweet and I will be stoked :yes:
I am pretty sure it goes on the Dyno tomorrow, probably fn blow up :bomb_ie:
This is what I am hoping for, keep in mind I asked for everything that could be done with what I have on the car , to go for response. If I cannot get it because of the Turbo or cams I will have them changed but I hope not to have to change anything ?
The car running sweet from turning the key to limiter
Full boost around 3500rpm
Go hard to at least 7000rpm
380KW + on 98 pump
420kw + on E85
It was 900Nm, not sure if that will change
Will I get it, who knows, have not had much luck so far , but there is always tomorrow, well in my case ?? lol
380KW + on 98 pump
420kw + on E85
Should do it pete. Mine does all that and more with rb30.
What cams u got?
What cams u got?
I have 260 10.8 UE custom cams.These are the same as Paul, Joey and a couple of others are using. They have a sharp ramp rate and the boys swear by them but have never been used on a 3.2,so ??
Excited
Both excited and apprehensive :/
Really do not want to put a Dyno up before I actually drive it.
I remember when I changed the cams and turbo on the 2.6 in the earlier days, there was only 7KW more but a much better car to drive. I can read the Dynos a little better now but I like to feel how it drives. Cannot wait to try it :yes:
  • Like 1
7 kW peak grunt. Only tells half the story as you found out. What was the difference through the middle? :P
You saw the dynos and you thought it was a lot better after looking at both graphs. It felt pretty good to me , much better than the T78 that did nothing until 6000rpm+
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
