Now enter SAU nsw trackday next Monday
That sounds great and as soon as I am sorted and everything is OK with the car I am going to start doing some of these days, Duncan suggested them.
I have to sort the steering out, it still pulls around more than it should , I thought it was just tram lining ? I am seeing my mechanic tomorrow and find the best bloke in the area to do the steering and then an alignment to see if it can be sorted. It can be spooky when the car wants to go where by itself.
There seems a little torque steer as well but it could be exaggerated by the steering problem. I thought there was something not right with it and Jez mentioned it and said there seems to be a problem and to have it checked out. Nothing serious but the steering is something I want right.
It was good to have a second opinion.
I'm glad you were able to have success with Jez pete. Is he not the friendliest tuner you have ever met? And his customer support is second to none.
Are you looking at getting the steering sorted back in foster? I can recommend Road2Race on the central Coast, they will sort you out no worries :)
Definitely should get mods to move to build section. You can keep us up to date with the OS88 install in there!
What is with you blokes, close it down, move it to another section , get over it ??
You whinged and put crap on me because I wanted response , it is my car and I will do what I want with it and if you blokes do not like it , PO.
Well I got it going pretty good and the result speak for itself and there is more RESPONSE left should I choose to go that way, you might not like it , but who cares what you think!
It is an RB30 conversion that is being tweaked , it is an RB30 thread, if you do not like it , go away, don't read it , or get it closed down BUT stop your whinging , close it down I do not give a rats !
There are blokes that have enjoyed some of it and seen the crap I have gone through over the past 12 months, they have also seen that I did not give up when the haters had their laughs and digs at my inexperience but they did not know my resolve and to them, thanks
The idea behind putting it in the Projects section Pete is that more members will get visibility to it, I'm sure fewer members look in the RB30 section than they do the Projects section.
It's been a great read and I'm sure many others would enjoy having a read of the thread, and then hopefully eagerly awaiting future updates!! :)
PS. The surge tank enclosure looks great :thumbsup:
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
    • Run some injector cleaner through it I had a similar issue that plagued me for months, even tried replacing the cat. If one or more injectors are blocked up the ecu sees ping so pulls timing and makes the tune rich overall, you'll see black smoke coming out of the exhaust and like me assume it's running rich but it could only be one or two cylinders  $10 bottle of injector cleaner and the next time I hit boost it pumped out a huge plume of black smoke, cleared the blockage and then ran great, if that's not the issue it's only a cheap thing to try haha
