I have had coolant poor down from behind the engine somewhere and passing down onto the ground generally when the car gets to temperature. . Rather than replace heater hoses which i think is the issue. I want to delete the heater all together. Is it a big job?
Just join the two pipes going through the firewall into the heater core on the engine side. Pull of a hose and get something like a brass plumbing pipe from bunnings that matches perfectly and cut to size and clamp the two hoses that would otherwise run into the heater core together. Will solve your leaking issue if your heater core is in fact the problem. Getting the heater core out of the Dash is a much bigger job from the inside.
Edited by sonicz
I just want to delete the heater hoping that is the problem.. what else could it be? Btw I have checked inside the car drivers side and passenger no signs of coolant leaking inside.
Edited by boobeedoobee
If it's not leaking inside then the leak is in the engine bay somewhere. Try as sonic and Ben have already stated and if it's still leaking you will have to find the leak. No other way around it.
Generic 1m lengths of oil and water hose isn't expensive, and by the sounds of it they will need replacing regardless.
If it is leaking behind the engine then you really have NO CHOICE but to find the hose back there that has a hole in it and replace it. And of course, because all the other hoses back there are old and crusty, you should do them too.
Deleting the heater would be a counterproductive effort that would take the same amount of effort as just fixing the problem.
  • Like 1
by the sounds of it you have a leaking hose which may or may not be a heater hose, I suggest finding which hose it is and replacing it.
If it was the heater core that was leaking the water would be inside the cabin
Ok thanks ill replace the leaking hose which your right might night be a heater hose. Just wondering though before I go and buy a heater hose kit..as I will be deleting the heater will this eliminate the need to replace the heater hoses?
Ben is there a way if getting around that after deleting the heater?
There are options, electric heater fan things for that very reason. I don't think j they actually work particularly well, but they satisfy the law.
I feel like in the time you've spent asking for ways aroung the way around, you could have just organised parts to fix the problem
I changed all my heater hoses with a Greddy copy plenum a few weeks back. Was a pain in the ass, but only took about 2 hours to replace all 4 heater hoses. Stop being lazy and fix the car rather than putting everything in the too hard basket.
Ok thanks heater delete it is.. save future leakage problems. Less hoses less trouble. I've never actually used the heater and never will. Wasn't trying to be lasy. Just needed to know what parts to organise depending on which way i went with it. Air con will go also
Google heater hose diagram rb26 and then decide on what you would like to do. Whether that may be replacing all hoses (I would do this) or cutting and blocking the heater hoses. It's one of the first things kids learn while driving around in beaters. Heat and plastic doesn't mix well after 10+ years.
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
