Seriously. , by writing what I did I'm trying to help you.
It's up to you .
Look at the result of your previous threads and consider my advice along with others.
Man just asking a simple question about a car lol.. not rocket science..
the standard RB26 plenum is pretty damn good.
maybe get it powder coated if you like the look of new stuff under the bonnet.
But really a new plenum won't make a bee's dick's worth of difference to anything except your wallet
  • Like 1
C'mon guys, sometimes it's easier to just either ignore the question and move on or just post a quick reply (or link to previously discussed topic) and again, move on! Bullying people over stupidity is still bullying!
My view- looks good, supposedly helps leaning out of cyl 6, apparently gives minimal performance gains.
Best option? Buy a cheap Freddy off Ebay and put a sticker on it, win!
Edited by Shoota_77
  • Like 1
Haha ok thanks.. it's seems that the general consensus is it makes no real difference and that money would be better off spent on something else..
The main purpose of the Greddy plenum is to help equalize cylinder flow, the stocky is known to push too much air towards cyl 5 and 6 causing them to run leaner than the other 4.
There is no power to be gained running one, stocky is good for high power builds.
Key point is to run the highest flowing injectors towards the rear to aid the lean issue.
So many people running the stock intake manifold to over 450Kw its not funny.
You suck at Google.
This was at the top first search and all I did was type greddy plenum rb26.
http://www.sau.com.au/forums/topic/265591-rb26-greddy-plenum-vs-stock-plenum/
Did you read that thread? Its the same old "wives group" shouting the usual and kind of lacking in actual results.
I am not saying they are an upgrade that people should rush out and do...but I have never read a credible back to back like i have with the Nismo plenum and Hypertune plenum.
I am curious and open to it because a mate that I respect who has owned more high HP Skylines than I will ever drive likes running them. And yes the std plenums make good power, but the Greddy item will give different results, different how is the question for me and as above curious....would be nice to read actual results from a semi sensible practical test.
    • I'm normally copping my own abuse from neglecting my daily drivers. "Those suspension bushes will last a bit more", "Don't worry about the oil leak, just keep topping it up". The project cars I'm always doing things slowly on them as I'm wanting them to be done better, and neater, and nicer. Luckily I don't have to deal with 18 year old Matt's "Learning to wire" stuff in the project cars. And there's only one piece of wiring I'm displeased about in the Landcruiser, and it's about to be cut out... However, the box loads of parts that have been going through this place lately for the Landcruiser... Brake pads Brake Rotors Full handbrake overhaul Wheel Bearings Seals Swivel hubs Steering Boxes Half the suspension joints Shocks Air bags (Ones to go in the rear springs for towing) Water pump Timing kit Lower timing case Harmonic Balancer Radiator Lots of other little seals and shits Gas struts for the bonnet New power window switches And god knows what else I've forgotten... Ha ha ha I have my fingers crossed the pinion seals don't start leaking on the diffs, that the transfer case doesn't leak, and the gearbox input shaft doesn't leak, nor the rear main seal. As they're about the only seals I haven't replaced in the driveline! I'm seriously eyeing off buying new caliper rebuild kits front and rear brake calipers... I'll probably recheck all the valve clearances soon too, and hopefully, it should be all good and sweet to haul some long distance trips again!
    • Every time I pull my 3x gauges out of the console and see the crack-addict way that I did the wiring, and I just can't bring myself to tear it all apart and "make it nice", because it is currently working. In fact, the last time I was in there I probably made it worse.
    • The best part is when you own the car long enough that you look back and find your OWN ham fisted amateur shit!
    • The annoying part about neglect, is when you start to replace one thing, and find ten more broken things. Ham fisted monkey repairs you normally only find out about when trying to do something unrelated! Ha ha   Neglect you can kind of anticipate the huge costs to fix it all. Ham fistedness is normally a shock the first time your work on a new old car, as everything "looked" good before.
    • For DBA, check out their guide table here. https://dba.com.au/wp-content/uploads/2023/01/Direct_Replacement-Guide-2021.2.pdf   Additionally they have some other guides and info on how to make sure you choose the right pad.
