If it has a flex then it's likely running a little lean. Without an exhaust temp gauge in the manifold or wideband running you will have no idea what is going on.
My exhaust temps usually run around 600c, but yours must be much hotter to cause cracking.
How much movement is in the motor when you start it or rev it? Can you almost balance coins on it or is it shaking? A suspect engine mount or even a gearbox mount moving the motor around when you are driving could also be a cause.........not the first option, but one worth checking.
  • Like 1
inb4 pass side engine mount broken and whole engine is leaning.
This is a joke btw. But did manage to fool a mate once.
When you get another manifold, why don't you get the surface machined flat, and make sure your mechanic is following both the torque and the sequence of doing up the nuts.
The only other thing I can think of is check your base timing to make sure it's not overly retarded and producing excess exhaust temp.
  • Like 1
I thought exhaust gases are hot when u r running lean
That depends on what you mean by "running lean". People use that term without reference to whether they mean "leaner than stoich" or if they mean "leaner than is needed to stop the engine burning up".
The simple answer is that the highest combustion gas temperature occurs at stoich. If you run leaner than stoich or richer than stoich the temperatures fall, due to dilution either from the extra air or the extra fuel.
If you need to run at 11.5:1 in order to keep the engine happy (no pinging, no self destruction), then going leaner from there will definitely raise the gas temperature. But until you get to 14.7:1 you are still on the rich side, so describing it as "lean" is only relative to the mixture it should have.
  • Like 1
I still stand by that being on boost for hours everyday in a tuned car can have this affect.
Doing this everyday is a lot different than getting a manifold red hot on a dyno once or twice or on a track a few times a month.
Didn't everyone agree that heat wrapping etc will cause cracks over a long period of time because of the heat, in the heat wrapping thread. Same principal applies.
The manifolds are worn and old now, shrink and expand with every drive. It's bound to happen
I don't think you could splash enough water up into the engine bay while thrashing it red hot to cause quenchy type cracking.
But I'm dead sure that an inadequately supports exhaust could exert enough force to damage the manifold, especially while it is hot. The hotter it is running the worse it could be. So you probably have to have more than one causative factor at the same time. Scenarios follow.
1) Thrashing it on the dyno. EGTs up around 900°C, so the manifold getting really hot. But there's little mechanical load because the car isn't being driven on the road so there's no up/down jiggle over bumps and no lateral loading either. Result.....probably no damage.
2) Driving it normally on the road. EGTs running around 500-600°C most of the time, occasional spikes to 700-800°C for short durations. Exhaust manifold doesn't run real hot, mechanical loading is applied from bumps etc. Chances of damage, probably small.
3) Thrashing it hard on a hills drive or sick dorifto styleez. Plenty of high temp exhaust gas to get the manifold really hot. Plenty of mechanical load from bumps or sick sidewayz action. Result, much higher chance of twisting the manifold past its happy point.
Edited by GTSBoy
  • Like 1
Yes that's what I mean.
Also a consideration is the turbo not being supported correctly.
    • Actually everyone on the roads was really well behaved. The only person that did any minor tailgating was a local hoon in a Turbo Focus. Unfortunately we weren't going the same way so there was no grand initial D touge battle. Lots of people pulled over and let me through. The amount of "Hey man nice car, omg skyline, nice 34 man woo" was suprising. Like really suprising. Like almost annoying. My partner was obviously surprised, she'd never seen anyone in the real world point out the car/like the car/want to chat about the car before, so to have like 3 people per day mention it was notable, I could finally say SEE? SOMEONE THINKS THEY'RE COOL. Everyone was also pretty suprised about the weather. Every day was dry and about ~13-14C. Mount Wellington had a sign that said they close the gates at 9pm and I was heading up there at about ~7:30. It was VERY apparent that conditions were getting significantly worse by the minute on the way up and down. The road on the mountain was terrible though, it's no driving road. I have various suspension related questions now. Luckily it was only about 20 minutes from where we were staying to the top of the mountain as said Google maps. We only had the 2 nights in Hobart. We went to the Farm Gate Market though which was really good - And went down to the Hastings Thermal springs/caves down there during the day. I'd definitely be up for going back again, so luckily there's a few more sights yet to see. Didn't get to do the west coast/queenstown/cradle mountain so this was supposed to be a 'scouting' trip anyway of sorts if I were to one day do/take part in/organize a more car-focused trip. As for the boat, it wasn't bad. Well it was bad, but not in the way you're thinking. We did the night trip which leaves at 6:45 (though you have to be there ~2 hours earlier) and arrives the next morning at about 6am. There is nothing to do on the ship. If you plan accordingly and bring a book/tablet/show to watch/charger you can just chill out, take some Travacalm and just sleep through it. The food there is an extremely basic buffet that costs $32 a plate, or $14 for a $3 pizza. The way back we had a travel kettle and a few different types of cup noodles and made our own tea/coffee in the room. This was a far superior way to do it. At the very least book one of the rooms with beds. I guess as we were in the off season we didn't have room mates. You get an option for rooms with 4 beds (2x bunks) or a room with just the two bottom beds. There's also some option for a deluxe queen bed but it's much pricer. We've been on sleeper trains in Asia before so we figured this is similar (and it was)
    • You just gotta be really, really, really clear and decisive with what you want your end product to be. 99% of people who want this conversion aren't "I want to run a 295 front tyre!" so they don't really need the widebody. They just want the OEM body to look a little less dumpy, so bonnet, bar, skirts job done with some camber, stretch, slam. It's when you want that, but then decide to pivot later you get big problems. See also if you're willing to get an all in one fibreglass bar, and you're willing to accept fibreglass problems like cracking the entire item on a driveway, instead of just a piece attached to the bottom, etc etc etc. Decide this all before buyin'.
    • After @Kinkstaah debacle, I'd never want to try and get it right 😛
    • The hood lines up with the fenders. The front bar doesn't perfectly line up with the fenders where the wheel arch is. You have to 'squeeze' the front bar 'in' as it wants to naturally flare out and be longer on the sides. There's a few threads where people notice this when they only swap a GTR style bumper and front bar. Unless you have genuine OEM items - you may be better served getting conversion kits. There are GTT bumpers to fit GTR hoods. There are GTR hoods (non genuine) to fit the GTT bracketry. MAY
