9 hours ago, Dose Pipe Sutututu said:
Like a boss!
Going to run a fuel cooler? Fuel might get a bit warm with those heaters haha
I want to get the car running and tuned. I know there will be gremlins to sort out so will take it as comes. Car goes in for fab work later this week. Some ceramic coating to follow then fire dis bish up. Cant wait to hear dat bridgeport idle.
So i spent some time tonight moving the now largely useless loom from the passenger side engine bay into the gaurd.
This connector was part of it. Does anyone know what it does? Does it need to be plugged in?
2018-04-14_11-18-41
Seems to lead to the wheel hub. Is it an abs or awd thing?
I looked this up at one point on my own car and yes I'm fairly sure it was the abs sensor
Yeah i think so also. Have extended the loom on the sensor and connected it up where it needs to go. All good, was lazy for a second lol
  • 3 weeks later...
2 hours ago, Old man 32 GTR said:
How are you travelling with the build, can’t be much left now?
Mechanical work is done. Fab work done recently by a friend. Work was top notch. Custom baffled catch can and battery mount, bracket for power steering reservoir, intake pipe and dump pipe with vbands, gate pipe welded up etc
2018-05-01_08-23-41
Got the manifold, dump, rear housing, gate pipe ceramic coated.
After i got everything back i got busy at home. Braided oil and water lines, braided wastegate hoses, moved wiring into the gaurd, sorted out power steering hoses.
A while back i wired up the io box with flex, oil press, fuel press, boost solenoid, map sensor, wb1 controller kit so thats all sorted.
Cranked it over last night. engine eventually started for a few seconds before the wife came in and was forced to shut it down. Guess i shouldny really be starting it at 10pm with the newborn sleeping diredtly above the garage!
After i actually get it idling ill send it in for tuning. Not long now.
2018-05-01_08-21-06
Sounded beastly. I forgot how much i miss it.
  • Like 6
1 hour ago, Old man 32 GTR said:
Awesome result, what boost are you pushing through it?
You’re going to have your hands full when it’s on boost
Thats on 32psi only. Can push it further but need a heavier wastegate spring.
  • 1 month later...
So managed to get 1 run in at wsid before they cancelled the night got cancelled. 10.8 @ 140mph.
Will try and get back out there and better the time. Launch was messy at 1.8 60ft.
2018-07-05_07-22-442018-07-05_07-22-17
Overall ecstatic. 10s first pass. No prep. Decided i was going to race at 6pm after i finished work. Didnt even check tyre pressures or oil level. Opened the garage and drove to the track. With 140mph, theres heaps of room to improve the time.
  • Like 3
  • 7 months later...
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
