I don't think this topic has been discussed much at all on SAU.
I know a few people on SAU use trickle chargers. This will be a first for me.
I bought myself a Trickle charger from Jaycar, but have been given advice that I need to disconnect the battery from the car so that I don't ruin the Alternator or other electronics if there is a current surge from 240V.
A few questions I have.
1. Owning an R34 GTR, where the battery in the boot, it's not very well ventilated. Are people removing their batteries from the car? Kind of defeats the purpose of a quick solution.
2. The car only gets taken out on weekends. Am i better off simply disconnecting the -ve terminal for the week? Have i wasted my $$$ on the charger?
What other tips do people have when using a Trickle charger?
https://www.sau.com.au/forums/topic/457967-using-trickle-chargers/
I do this,
Disconnect +Ve side on the battery and leave it. It has been fine for me for up 6 months.
When I come back from lengthy times away, I put the car on the trickle over night and that is perfect.
With the +ve side disconnected instead of the -ve I don't see how there can be a problem with sending a surge through the car....
Given that there is a 20:1 step-down in the charger (240V input, 12V or so output) there would need to be a huge input voltage surge to damage any car electronics. Do you have a surge arrester in your meter box - a big enough surge to damage anything in the car will also take out most of your house electronics.
I use a 1 amp trickle charger on a motorbike, but I run it off a timer so it's only on for an hour each day. This helps prevent over-charging the battery. Have done this for many years and battery life has been great.
My experience is using a Trickle charger is fine.
In my case If I disconnect the battery the mongoose alarm goes off.
So I leave both terminals connected while charging.
Generally only connect it up if I'm leaving the GTR in situ for over a few weeks.
Having it on a timer is a brilliant idea. Might give that a go. The charger i got is:
http://www.jaycar.com.au/PRODUCTS/Power-Products-Electrical/Charging/SLA-GEL-Chargers/6V-%26-12V-Heavy-Duty-8A-Car-Battery-Charger-with-Trickle-Charge/p/MB3522
I guess my main issue is that the car is kept in a downstairs garage (unit block) and I don't want to come home to an inferno. I understand that most batteries when on charge can emit gasses, which could cause a fire.
If anyone has seen the battery location on a 34R, it's an enclosed, tight space with a tonne of carpet surrounding metal
The whole idea of trickle charging is to leave the charger on the battery constantly. I don't like charging at high voltage/current with the battery connected in the car, but trickle charging should be fine.
When you are driving the car the alternator is charging the battery, so there should be no difference really
The BNR34 has charging terminals in the front under the fuse box.
The main possible problem is reversing polarity (by accident).
If you're so concerned about surges from lightning strikes just put a surge protector between the trickle charger and the power point the same way you protect your computer.
Learn something new everyday. Did not know that. Makes it a hell of a lot easier if this is the case
  • Like 1
Lol, look at the fuse box and you will see a (+) and a (-) each next to a metal tab. Surely you didnt think that if you wanted to jump start your car that they would make you do it in the boot...
ok ok, geez, chill out man.
    • Perfect, I'll get to it this winter then at the same time as I weld on my anti squat kit.
    • Alright so my 32 only has one temperature no matter what degree you set it to. I’ve tried disconnecting the servo motor arm and moving it either direction and got no change. I’ve fixed the leak in my AC and re charged it and with it on and clutch engaged it still blows hot even though the low pressure pipe going to the firewall is ice cold. Both heater core hoses are hot while running as well. Diagnostic code showed 24 for intake air temperature sensor. Anybody got any ideas?
    • I said Garrett style. Not Garrett genuine. And something in the G30 550 range is what you want. Not those pokey little old fashioned T28 sized things. The intake ports in the head are small. There is little benefit in fattening up the runners and leaving ths actual ports small. Just run what you've got. And on the subject of Nistune vs Haltech etc..... You know you can control the transmission with decent standalone ECUs these days, right? No need to keep any of that old Nissan bullshit. Don't get me wrong - I use Nistune on my Neo. But it is a DET, so the number of bodges and workarounds I had to do to make it work in a chassis without ABS, TCS, etc, is quite small compared to the herniated arsehole you will have trying to make it work on a motor that doesn't have some of the things that the turbo ECU wants to see. Just easier to bite the bullet and go aftermarket outright.
    • Hmm. Only when the f**king thing is actually working. Still can't find the leak. And that's with dye being put in the last 3 times!
