I got the rear end in yesterday, bled the clutch fitted the rear shaft and also replaced the nitrogen canister A4128799-E36E-4675-9A66-33530C812C27.thumb.jpeg.96a960982d9d9d850273d6b26b30845f.jpegnew and old next to each other
took the car for drive and the difference it amazing, was worth every cent. Now I just need an alignment before Friday
Just out of interest (Doubtless has been asked) but how much for the canister?
  • Like 1
Because I hadn’t started the car for ages there was already no pressure in it.
I had to buy a big socket go around it and remove the pressure switch to get the socket in there and then it was just unscrew the old one and fit the new one
Keeps the pressure in the pump, easiest way to know if yours is stuffed is while car car is sitting there idling you’ll hear the attessa pump cycle every couple of minutes.
    • The final part arrived today to un-clampify and simplify the intake Who would have though a 1/2" hose stainless bulkhead fitting designed for below waterline bilge pumps would be what I needed Test fit on a 3" offcut I had laying around to see if it would work, and it worked a treat All going well the intake will be on its "final version" tomorrow
