The intake pipe was made up and the blow off valve pipe modified so they will recirculate.
also took the blow of valves out of the car 7EEDBB46-9E19-4D65-BE83-313A2B673C65.thumb.jpeg.278024be8ad2cd7dc115f6f7a8310bcc.jpegand swapped over to a set of bolt on gfb ones 44C33312-2AD2-404B-8120-B20B9981B137.thumb.jpeg.b9165f3b4e7c5ee1fa8396b0777d8731.jpegand then put all the bracket and etc back on so they’re ready to fit back in the car 9A30F535-04FB-4071-BE91-7F0BB3B26888.thumb.jpeg.74220a455b9309a241fb94a6b6a15e63.jpeg
  • Like 1
Could have saved money and not run any BOVs, more money for bags and bitches lol.
Also dose is better than whoosh noises, and you're not running a BW, it's  it going to explode with the wrong shaft RPM or a bit of pressure against the compressor when the throttle is shut ?
Also Dose Pipe Sutututu: (note, this is not a BW)
On 17/12/2016 at 5:43 PM, Dose Pipe Sutututu said:
yyyeaahhh mmaateee kakafuarkingdu..
Overspeeding and compressor surge at high wheel speeds are both things known to break turbos since god knows when - they are why blow off valves exist, and why compressor maps are done with a cut off point which is earlier than where the flow completely chokes.   These phenomenon have been recommended to avoid since they have been breaking turbos since WAY before EFRs existed, and have broken pleeeenty of non-EFRs since well after they were released.
Telling people that it is only an issue for EFRs is pretty bullshit advice for people you are giving it to, and also a pretty major exaggeration of the fragility of EFRs.
Calm down @Lithium you clearly don't get a joke, also that turbine snapped because my motor exploded and put chunks of metal through the motor, not because it was oversped.
It was a joke, same way you and your buddies tell the world Precision turbos are junk and you need 15 oil filters.
  • Like 1
There wasn't anything put in there to make it seem like a joke otherwise I would had just lolled.   No worries about my level of calm, I just don't like seeing bad advice being left unquestioned... if it wasn't clear to me as a joke then it may not be to others so had to make it clear that it's very wrong - joke or otherwise.
I have no idea what that last line is about, but you appear to be confusing me with someone else.  I have opinions and friends have opinions, they sometimes overlap and sometimes they don't - whatever you are talking about there is nothing to do with me.
Edited by Lithium
Nah I don’t really want dose, always like the way the gtr valves sounded
Picked this up 376983A4-FCDE-4442-83BE-77FC3C7D216C.thumb.jpeg.8ed40213c04622b9d7acd144ca9b456b.jpegit the electric power steering pump out of an astra
and after modifying the bracket to it’ll sit flat I worked out I’m going to sit it about here D0E84407-405D-4B2F-972A-17CBCE20316D.thumb.jpeg.ac6e832d1566dd2fdccbc84041ed7a73.jpeghaven’t mounted it yet just sat it there and went to the fitting shop
Does that one have a vehicle speed input? At least you won't throw PS belts anymore (if you ever did).
I kept spitting PS belts when the motor was spun close to 8.5k on the limiter at a skidpan. Had to pop it back on twice then ended up lowering thr rev limiter (no fun in that).
No it’s just stays on and I’ll use the factory solenoid on the rack to change the power assistance.
i never had belt throwing issues, it’s just for room and trying to tidy up the bay a little
Fuark. When I was doing mine I was wondering if I should do it like this or black. I bitched out and went black.
Hurry up and get this fitted so I can hate you even more haha
#sexspec
Edited by WantGTR
  • Like 1
  • Haha 1
    • Yeah I've had too many issues with knock off's on the BMW's. I don't want to do a job twice or more because the parts are shit.
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
