8 hours ago, BakemonoRicer said:
I reckon I'll smoke you in my R1 GTR mate,
honestly...
p.s. i flatshift at 8850rpm.
z-tune engine vs brett single turbo from a standstill, show me the money pal (and if i win you have to reply to all my sau posts and refer to me as big daddy)
What ever helps you sleep at night
17 hours ago, admS15 said:
And if you lose?
His arse....
Still, from a outsider looking in, he talks the talk, but I haven't seen any slips or natsoft times.
Not saying his builds aren't impressive, it's just they have massive holes that let the rest down.
It's weird, his S15 is the most under engineered over engineered build I've seen for years.
Meh, let me know when you hit the strip, I'll bet a bag of donuts my old $10k VX SS commodore smokes Bokemons S15.
And it will do it all night long.
Now, where do I put this dirty spoon....?
This will cheer you boys up, Tiguan under 2 years old with less than 29k kms on it has a cracked thermostat housing.
It's going back next week for a new thermostat housing LOL.
  • Haha 1
Das auto
19 hours ago, mlr said:
His arse....
GTR is full house. S15 will be full house with a bottom end, gearbox and brakes, not too far off, the rest of the car has had every part replaced LOL. When those big three items are working fine I'd rather get use out of them until they break.
I entered the Easter roll racing event and after it being cancelled again and again due to some flu going around the event was finally run on Friday night.
I have managed to fix the traction issues and the car ran pretty much straight all night, I started on the lower boost setting and got a feel for it, then went up to the medium one and got a feel of that. Then I turned it up to the high setting and got a slight wiggle in the steering wheel but nothing to worry about but then it happened....... It lifted the head :(
if I’m honest I can’t say it wasn’t expected, it’s the original head gasket that had some head studs put in without removing the head. So now i need to decide where to go from here
here’s a video of the run where the head lifted, yes I got destroyed by that lambo
  • Sad 2
Inserts "Get a Samsonas" joke?
Damn man, so it was running after market headstuds and still lifted the head? Probably head gasket was breached in the past.
Just send it, build it and put a Samsonas behind it.
  • Like 1
Great build mate, it’s come a long way, I think you are just around the corner from me, I live in Harrington park, we should organise a drive one day, if both cars are ever running at the same time ??
Also, I’d love to pick your brain on a few things, seems our builds are similar. Mine lifted the head a while ago, got it sorted now but the build has kind of run away from me and is doing what it likes, I just pay the bills ?
  • Like 1
Thanks mate, looks like we are around the corner because I’m in Currans hill. Would love to go for a drive some time!
I don’t think my build will ever be to the level of yours but anything I can help with I’m happy to help
3 hours ago, r32-25t said:
I definitely don’t want to end up as far down the hole as you but I’d like to fix some weak points
Crank collar, Nitto oil pump, restrictors, sump vent, bearings, new seals all round, and Samsonas ?
Samsonaslines Australia?
Well the box it out againF810E9E1-7F7D-447F-B49B-4E9D0AA9143F.thumb.jpeg.86e70b26cebf145f49d4bec50663e27f.jpegAnd was sold to someone in Melbourne
Picked this up along with a few other bits I need to make the new gearbox work
and 10 of these to rebuild it and hold the extra power it’ll be making F5EBAAEB-B350-4325-9B5A-EB424BE45625.thumb.jpeg.8eecbeeca9d9dadae9b8abf6bc4544db.jpeg
  • Like 1
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
    • The video for the servicing and fuel filter change can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44 One of the main jobs I wanted to do before the car officially went on the road, was to remove the awful looking blue silicone hoses. There's nothing wrong with having coloured silicone hoses, but I realise as I'm getting older I prefer monotone engine bays with a splash of colour on the engine cover(s). I cover this in a lot more detail in the Youtube video, so unfortunately there's limited photos of the process. The intercooler, upper radiator, boost vacuum and upper breather hoses were all changed to black silicone with mikalor clamps. The only blue left is a blanking cap at the back of the inlet manifold and the GReddy pulleys (which will be replaced for stock when the cambelt gets replaced) While the intercooler pipes were off I gave them a quick clean/polish too A before photo I do have a replacement air filter on its way. Fuse box covers were painted blue, they're now satin black Another job on the list while the bumper was off, is to add some mesh https://live.staticflickr.com/65535/54737966256_99b28bfa30_c.jpg[/img] I was hoping to use some thin wire to secure it, but it seems I've misplaced it and the wire I had was too thick to twist easily. I ended up using cable ties for the time being https://live.staticflickr.com/65535/54737131882_c2b7989dcc_c.jpg[/img] Was pleasant to see this https://live.staticflickr.com/65535/54737131627_8b2aab13b3_c.jpg[/img] The last thing to do was to fix the front grill and re-mesh that to match but I ran out of time The Youtube video can be seen here: https://www.youtube.com/watch?v=R4FsF6tgizE&t=23s
