On 8/12/21 at 11:05 AM, Dose Pipe Sutututu said:
That's pretty decent in terms of pricing, tempting LOL..
For the money you’d be crazy not to, putting old manky looking bolts in a fresh bay makes it look shit
  • Like 1
  • 3 weeks later...
seeing as I can’t do a great deal with the front at the moment I decided to do some work at the back of the car
in go some rear camber arms to stand the wheels up a lot more
once installed I dialed the camber down to half a degree, the toe is still all over the shop because I didn’t have the string lines to be able to measure it
  • Like 1
On 6/1/22 at 5:31 PM, r32-25t said:
I got told yesterday the pistons have arrived and will hopefully see some progress with the engine soon
2000hp on the way 👍🏼
  • Haha 1
On 07/01/2022 at 8:18 AM, r32-25t said:
Lol there no way I’d put up with the lag a turbo big enough to flow that would have
Never say never. You said that about never putting a single turbo on your car too.
Quoted for future reference. 🤪
Lol and that improved response not killed it
Well seeing as I couldn’t go to work because of getting beer flu I decided to work on the gtr once I had enough energy.
Pulled the rest of the interior out and removed the battery wiring, the battery tray ready to re wire the entire boot. Then I fitted the surge tank in the corner of the boot
then started plumbing the tank into the fuel lines I already had
I had to wait for 60° fitting to do the last line as it wouldn’t run where I wanted it to without it
I’ll be wiring in some solid state relays and etc, just need the engine to turn up and the new wiring harness before I wire it all up
  • Like 1
Fitted all the brake lines back into the bay with all new clips to hold them onto the firewall
also fitted some nismo braided brake lines as they follow the factory routing and make a lot less nervous that they may end up touching and rubbing through
also some new break clips as it seem the old line stretched the original ones
  • Like 1
Then I bled all the brakes using good quality brake fluid, put all the wheels back on and now I pretty much can’t do anything until the engine and wiring harness arrive
Looking nice!  Hard to beat a nice clean engine bay!  I see you’ve given the ABS module a tidy up?  They’re a tricky shape and setup to be able to do much with. So tempted to delete or relocate mine.  Even just route the pipes somewhere else. Lower on the firewall maybe?   Or just stop being a wanker and finish the car! 😂
  • Like 1
I had it vapor blasted then put it back, I wanted new lines but a few a discontinued
On 29/1/2022 at 5:32 PM, Old man 32 GTR said:
Wiper motor looks nice as well, how did you clean it? Or did you buy new?
i also had it vapor blasted and then painted the black bit to make it look as new as possible.
On 1/21/2022 at 7:43 PM, r32-25t said:
How have you found the steering feel with the pump in the boot?
On 1/29/2022 at 3:02 PM, r32-25t said:
Engine bay is looking great.
  • Like 1
It’s good, if it wasn’t for the fact you can hear it wind up before you start the car you’d never know
thanks mate
Something little but has been a pain in the ass for ages
the spring for the fuel flap went missing when I gave it to someone for paint matching years ago and I was able to buy one new
quickly clipped it onto the flap and now when I open the door it pops open again. As I said it’s a really small thing but sometimes they make big differences
  • Like 2
