to fix the voltage drop issue I swapped out the old 150amp alternator which turns out is a brand known for having issues and replaced it with the black 180amp alternator beside it
  • Like 2
  • 3 months later...
Took it for a drive to do some logs, I’m pretty sure my voltage issues and electrical noise issues are gone, I’ve sent a log to Adam and am waiting to hear back with confirmation
idle video from that day just because
  • Like 7
  • 1 month later...
Can I be your first customer?
I would like hard lines done for the fuel system, 8AN up and 8AN back and the underside wire wheeled and coated (brush or sprayed) with that black tar shit.
  • 4 weeks later...
What alt kit is the 180amp one? FPG?
https://lamspeedracing.com/products/nissan-rb-180amp-high-output-alternator-direct-fitment-rb20-25-26-30?srsltid=AfmBOop9-VWIXaJSdAL0BZh0XJVdn9-996NFg_tWyqBbbHmEswJsQX6h
that’s the one there, I couldn’t use any of the ls1 based one due to the oil pump
  • Thanks 1
  • 4 weeks later...
Decided we would get it tuned before gtr fest, due to some delays with other cars mine went on the dyno at about 6pm Friday night.
98 tune done we start flexing 10% 20% 30% all the way to 80 and then it’s time to give it hell aaaannnnd miss on number 4 😔 change plugs, still there, check coils, still there, decide to swap injectors to see if it moves, rev clean!! Try again, revs clean??
I made the call to pull the pin anyway because if it decides to play up with 35-40psi of boost in it and 7,000rpm, it will torch a cylinder before you’d even realize it had done it and I’m not risking it for a $200 injector. So new set ordered
we did make the car drivable so I could take it to gtr fest. Finally got to drive it on e85 (slowly) its even better then it was! It’s so responsive, with under half throttle it cracking gate around 3,300 but mind you it is only 10-12psi at the moment
  • Like 6
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
