Tis a sad state of affairs when people are vying for positions in pre schools.
Back in my day your parents just rocked up with you at...kinder...and they took you on the spot.
What's next, scholarships for toddlers?
ok housing / finance ppl.
found a house interested in.
it's a house and land package with Dennis family homes.
then I see this:
http://www.dennisfamily.com.au/1500-down-offer
any idea what the catch is? things to look out for?
then I see this:
Can i get some cliffs?
We got Orlando into the preschool we wanted!
This is what I have to get excited about nowadays.
This, food and scotch
Tasty tasty scotch
Whats the benefit of this preschool compared to others?
Considering all you learn it to nap and play with lego's at this age?
1500 deposit to get a home, (plus the first home buyers grant)
it cannot be that easy.
if we buy this one it is only to live in for 3-4 years whilst we find a plat and build the dream house. then rent it out.
basically instead of renting, so if I don't have to use my deposit means that free for when the right block of land comes up.
or am I massively over simplifying things
You can get assigned to the one near you etc... so that's still a thing
However the best one in our area (IMHO) is the one we got into... we are less than 1km out of the zone so it we are a second preference at best.
Probably helped that my Mum is a 40 year veteran kindergarten director and will be volunteering lol
They don'y sleep in preschool... well generally speaking.
This one is educational, has a small teacher/child ratio and gets LOADS of funding.
It also has animals, nice grassy areas and grows their own fruit/veggies etc.
Don't underestimate the importance of Kindergarten, this is the time their brains are developing the most of their whole lives, so you really don't want them somewhere they will be ignored / not stimulated / not enjoy it
Probably no catch, unless you need to get finance through them at a higher cost
Maybe we just have different view on schooling
Ill just send my kid to the nearest kinder primary school, then ill send them to the best nearby public school
Alex you ahd any experience with this sort of thing?
I see kids on the train every morning travelling ages just to get to school, f**k that.
Not many of them are aussie, maybe cultural thing?
lol its because you're on the dandenong line. not many caucasians in general. plenty of tru-blu private school kids on the frankston line. Mornington to Melbourne High, anyone?
Kids at school were playing it yesterday with username Pinis. I told them to at least spell it correctly
I'm pretty that pinis kid killed me yesterday, I laughed when I saw that name before he ate me...
Speaking of kindergarden, only thing I remember from that was using a plastic bag as my school bag and getting slapped by a girl I think because we crossed footpath on my bikes and we both couldn't pass eachother because neither of us refused to ride on the grass /dirt.
Scared for life man, put that kid in a proper kindergarden! Lol
I'll be sending my kid to the closest schools and that's it...plenty of shit kickers in good schools and plenty of bright kids in shit schools
Parenting at home > influence than parenting at school
Was it Alvin?
    • @666DAN sorry to bring you and old thread.     I've got my de+t done and it's all running great other than 1 small issue.    Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd when selected . But nothing when in  drive or what gear your in when you pop it into tiptronic. I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Do ya have any ideas?     Cheers man
    • Well I recently changed my rear axles and was thinking if I bumped anything, I have been driving the car for a while now though... But it has been raining today so everything is wet under the wheel arches. Brakes feel fine and can't hear any of the metal screamers, I had a squeak coming from one of the handbrake drums but that seems to have gone away a while ago. I was going down a hill when it lit up and I did feel the abs bite for a second and question why it did it?
    • Correct. Um. I dunno. I haven't cared enough about the way that the NA cars work to know for sure. But..... The 33/34 turbo manual cars have an electronic speed sensor in the gearbox that outputs a +/- (ie, sawtooth AC) voltage signal. That is connected to the speedo. The speedo then outputs a 0-5v square wave (ie, PWM) signal that the ECU (and any other CU on the bus) sees. The speed sensor is NOT directly connected to the ECU. So here's the problem. Your new ECU expects to see the PWM signal, but must somehow be getting a direct signal from the diff speed sensor. Which would suggest that the wiring of the NA car is not the same as the turbo cars. I think you will need to spend some time with (hopefully the wiring diagram for the car) and a multimeter to see what is connected to what. Then, presuming I am correct**, you would then want to separate the ECU speed signal input from the rest of the car's wiring, and probably either buy a speed signal converter, or build one using an arduino (or similar). That would take in the speed sensor signal and output a scaled (and suitably rearranged) signal for the ECU. ** We shouldn't presume that I am correct here, because there might be something else crazy going on. I don't think you could convert the speedo to be fed from the gearbox sensor, because the pulse rate from that sensor is probably different to the diff sensor and then the speedo would read wrongly. And this also wouldn't fix the ECU's problem either, because the ECU doesn't want to see the gearbox signal direct either (assuming that they are all on the same wiring, for some odd NA related reason, see above caveat!) Does this help? Probably not. Can you make it work? Almost certainly. With the above work. You should buy a handheld oscilloscope from Aliexpress so that you can view these signals directly. Connect up the probes and drive the car. Show photos of the screen when drving at known speeds and connected to different places, and we'll see what we can learn about it.
    • Assuming your brake pads are not worn right down, I'd add a little brake fluid. Is there any sign of a brake fluid leak?
    • Hello all,  I need of some help. On my drive home my handbrake light lit up and started flashing. When I got home I checked my handbrake sensor under the centre console and nothing seemed out of the ordinary. I have scanned my car via the consult port, no codes shown. Checked my brake fluid as well which is half full. Tried unplugging the brake master but it didn't change anything. Thoughts on what it could be? The master float doesn't seem to be stuck. My car is an 1998 ER34 sedan GT. No hicas but has ABS Photos below 👇🏾
