It was about as serious as the prospect of taking an a5 to a workshop that we frequent to get it done...
Either put some trust in a euro workshop to do it, or don't modify it...
Now, this is a story all about how
My life got flipped-turned upside down
And I'd like to take a minute
Just sit tight and wait
I'll tell you how I became the prince of a thing called Real Estate
In western subnurbs born and raised
On the hard clay ground was where I spent most of my days
Chillin' out maxin' relaxin' all cool
And tellin everyone they dont need to be schooled
When a couple of illegal immigrants were jumpin the border
Started making trouble all up in my corner
I got in one little internet fight and my mom got a look
She said 'You're movin' with your auntie and uncle in Point Cook'
I begged and pleaded with her day after day
But she packed my lexus and sent me on my way
She gave me a kiss and then she gave me my keys.
I put my Tupac on and said, 'I might as well leave'.
First class, yo this ain't bad
Drinking burbon cans out of a champagne glass.
Is this what the people of Point Cook living like?
Hmmmmm this might be alright.
But wait I hear they're Labor, Left wing, all that
Is this the type of place that they just send this conservative cat?
I don't think so
I'll see when I get a look
I hope they're prepared for the prince of Point Cook
Well, the policies lowered and when some gays came out
There was a dude who looked like a flog standing there with big ears sticking out
He said gays should be arrested like illegals that just got here
So I discrediteded some memes of eating onions and skolling beer.
I whistled for a lexus and when it came together
The license plate said Sherwin and it had luxurious white leather
If anything I could say that this lexus was expensive
But I thought 'Nah, forget it' - 'Yo, Labors economic mismanagement was extensive'
I pulled up to the office and there was this fob
And I yelled to the unionised leftie scum 'Yo flog get a better job'
I looked at my kingdom
I was finally through the gate
To sit on my throne as the Prince of Real Estate
  • Like 1
The point isn't because the car costs more, even when I had my 33 didn't want it treated shithouse - which it was regularly. unfortunately the industry is a bit substandard in that area IMO.
So much butt hurt from the battlers
Good see tall poppy syndrome is alive and well
Tall poppy syndrome is attempting to cut someone down ONLY because they are successful and one is jealous of same.
If you hadn't spent the last month bragging it would have been TPS
FWIW I get that you are trolling... but it was too good to pass up
Ya'll too easy tho mention a couple dollars erry body lose they mind
point still stands about wanting a decent work shop tho
Edited by alr33x
Try making a booking at zagame's Richmond.
srs.
Will coilovers void Lexus warranty? I know warranties can be funny with "expensive" cars.
Not doing cool overs thought about it but too much headache and lose the adjustable dampener bs. Just springs they give it 1.5" all round which is pretty much perfect for everyday and will sit nice with 20s
Coils look hot tho
Coils look hot tho
Unnnnffff! That does look good... What colour is yours again?
Do you ever have clients in the car? Will a 1.5" drop lower ride quality enough to bother them?
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
