Well Dezz the reality is that even slashing their pensions and entitlements etc would make a minuscule difference to the overall books. Not to say I am for it just the reality.
The unions on the other hand butcher and stifle growth through onerous conditions and wage growth expectations (demands) ie train drivers .. What next $200k a year? Gimme a spell.
Edited by alr33x
Cut the fkers, maybe then we'd have politicians who want to be in the job to make a difference and not for the pay packet / pension / expense claims.
It's really hard to buy that a politician is any way in touch with most of the population when they live within the upper 10% of it. I believe they start off with good intentions, but the things they do to get office, the deals they make and the souls they sell change them into power hungry ego tripping cretens.
  • Like 1
You'd have to be pretty stupid to take a paycut to save your employer money when they could just sack you whenever it suited them
Because companies just sack people for fun and no other reason
Anyone truly worried about getting sacked should consider that they are perhaps a dud
  • Like 2
+1 have been involved in the selection of people to sack due to budget cuts. It's the duds which let go first. (Or who the manager doesn't like) #workpolitics
Nail on the head
Yeah but on the flip side a majority of American politicians are extremely wealthy and the system is no better
Not sure what the answer is
Yeah, i get that... royal kingdoms of years past being an example... my point was it will always fail when a nutcase get in... (or the guy thats in becomes a nutcase)
This. But didn't you put a 26 in yours?
The 25 is the superior engine in almost every way save for .1 litre displacement
Not even the throttle bodies and no crossover pipe can save it from that debate
But people want it because GTR engine, even though putting it in a car where the engine is the only thing GTR about it
Nah still have a 2.5 Neo motor
Stock RB26 still be faster than your engine Tony :P
Probably since its not really working at the moment :(
Was curious mainly cause my engine exploded, and I know yours kind of did, and kind of went back, and kind of has issues, so I have a vested interest in your car also working right ;)
Getting flex fuel right though, man... requires mastery and a lot of patience, or a f**k load of money paying a tuner to have a lot of time to spend on it
    • @Haggerty this is your red flag. In MAP based ECU's the Manifold pressure X RPM calculation is how the engine knows it is actually...running/going through ANY load. You are confusing the term 'base map' with your base VE/Fuel table. When most people say 'base map' they mean the stock entire tune shipped with the ECU, hopefully aimed at a specific car/setup to use as a base for beginning to tune your specific car. Haltech has a lot of documentation (or at least they used to, I expect it to be better now). Read it voraciously.
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
