I hope you wont be daily'ing on A1RM's...
I chewed through a brand new set of rotors using A1RM's through daily driving.
Had a chat with the marketing rep - advised me that when pads are cold - they chew through rotors.
He advised me to switch to HPX & I haven't had any issues since then.
Can vouch for this, have already machined my new rotors which weren't that old and coming up to a second machining soon...can feel the vibrations beginning
when I had A1RM went though 2-3 sets on a set of cheap as RDA rotors, daily and track..
strange.
Comes down to how you commute in the morning. If you are stuck in peak-hour traffic, the pads will take much longer to reach temp.
but... but.. that is literally the entire, somewhat valid argument
lol yeah sure it is since they represent a minuscule % of overall transactions
But believe what the paper says it's more interesting to the lefties
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
