I'm thinking about another Evo... might grab a 9 this time.
They are great cars man. They just need a good 230+ AWKW
Skylines have ruined 2 litre engines for me
It's fine after you get used to the 2 litre
But then you get back in a Skyline and man do you notice the 500cc you're missing
I'm constantly surprised by the low end torque the 4g63t has, even before it's come onto boost (which happens very early, compared to the highflow on the 2.5)...
But it's still not a car that really makes you moist and love driving, especially at what I estimate to now be about 160awkw...
SR's are great and all... but fark the GTiR and its shims. whats the difference between a noisy GTiR head and a quiet one? apparently 2 thou (0.07mm) of shim.
i found that out this afternoon. $71 and 6 shims later. prick even charged $2 packaging and handling... i f**king picked it up.
Don't underestimate 2L.
The later focus and Mazda MPS 2L (or 2.5's for that matter) are basically built for down low.... It's just up top they waver (from factory)
Rather have the extra .5 giving torque everywhere
Maybe it's my turbo and engine combination but I love my RB25, it does so well everywhere
Lol, 334HP 230KG aussie built superbike and it's in production
that's insane
http://pgmv8.com.au/spec-sheet/
birds you wouldn't even get one brah
Edited by UNR33L
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
