https://www.youtube.com/watch?v=koPQnNZdco0
Lol, 334HP 230KG aussie built superbike and it's in production
that's insane
http://pgmv8.com.au/spec-sheet/
birds you wouldn't even get one brah
But in all real, I don't get the fascination with so much power in a motorbike...unless going for top speed records there's only so much of it you can put to the ground, without ridiculously long swing arms and fking with handling
Anything above 250hp in a road going superbike is a waste IMO
I am yet to see roller dyno figures of torque that actually seems reasonable. I'm not sure how it's calculated or if the tuners just can't be bothered setting it up. Trents hub dyno gave the most accurate reading of the 4 dyno/tunes the pulsar has been on. 900Nm is wrong... A sheet from edge said similar things, but ballpark of 450 is much more realistic
  • Like 1
This
net glitched out.
got locked out of our NAB business account.
account is in my name and partners name.
nab acknowledges that i am also on the account, wont give me a new password.
partner is currently OS.
daf**k man.
Birds, on 13 Oct 2015 - 3:39 PM, said:
Skylines have ruined 2 litre engines for me
It's fine after you get used to the 2 litre
But then you get back in a Skyline and man do you notice the 500cc you're missing
tbh... I was driving an Evo X, which has about 210 at the wheels.
Now, its a 6 speed, but apparently they weigh 1650kg
So it should be laggy and slow
not so, it was punchy as f**k and felt far more zippy than my 2.8
regrets, I had a few
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
