VB is a strange beer, it exponentially gets better based on how hot the day is, and how cold the beer is.
This is an undisputable rule of the universe, no matter how uncomfortable.
Unless the day gets too hot to sustain human life, or even worse, the VB freezes
Also, this is really all beers
It is, but VB is kind of unique in its shittiness outside of this scenario, and its relative goodness in this scenario.
It's kind of similar to the relationship between being drunk/hungover and McDonalds
Welcome to the world of beer,
every beer is brewed to match certain conditions where it is drunk.
Same as drinking CHang in AU winter tastes like ball sweat (don;t ask how I know this) where as kicking back ona beachin summer is awsome.
try drinking a German cloudy wheat beer in middle of summer here, you struggle, where as when it freezing cold outside and you have some Spätzle works a treat.
and then there heineken, Amsterdam's beer, and I swear you must be on drugs to enjoy that.
so kick back, enjoy and make the most of what you got.
  • Like 1
new trend for Evo's at WTAC: remove the entire boot section between the rear pillars. surely its we're not far away from driving a a full carbon front, no boot, chasis rails and cage in the middle.
As of tonight mine will have twin 3" :D rumblerumblerumble
Probably remove the supercharger 'silencer' rubber thing that quiets it down too.
Get a v8 m8
Edited by UNR33L
Also VB is good in ALL scenarios.
is it to rear mount a radiator and fit a bigger turbo in?
joeyjoejoejuniorshabadoo, on 16 Oct 2015 - 11:45 AM, said:
Just saw a stanced (ish), murdered out, VF R8 with cams and and exhaust.
This makes me reconsider many things....
You sure you're a hipster?
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
    • Bloody apprentices! 🙄
