VB is a strange beer, it exponentially gets better based on how hot the day is, and how cold the beer is.
This is an undisputable rule of the universe, no matter how uncomfortable.
Unless the day gets too hot to sustain human life, or even worse, the VB freezes
Also, this is really all beers
It is, but VB is kind of unique in its shittiness outside of this scenario, and its relative goodness in this scenario.
It's kind of similar to the relationship between being drunk/hungover and McDonalds
Welcome to the world of beer,
every beer is brewed to match certain conditions where it is drunk.
Same as drinking CHang in AU winter tastes like ball sweat (don;t ask how I know this) where as kicking back ona beachin summer is awsome.
try drinking a German cloudy wheat beer in middle of summer here, you struggle, where as when it freezing cold outside and you have some Spätzle works a treat.
and then there heineken, Amsterdam's beer, and I swear you must be on drugs to enjoy that.
so kick back, enjoy and make the most of what you got.
  • Like 1
new trend for Evo's at WTAC: remove the entire boot section between the rear pillars. surely its we're not far away from driving a a full carbon front, no boot, chasis rails and cage in the middle.
As of tonight mine will have twin 3" :D rumblerumblerumble
Probably remove the supercharger 'silencer' rubber thing that quiets it down too.
Get a v8 m8
Edited by UNR33L
Also VB is good in ALL scenarios.
is it to rear mount a radiator and fit a bigger turbo in?
joeyjoejoejuniorshabadoo, on 16 Oct 2015 - 11:45 AM, said:
Just saw a stanced (ish), murdered out, VF R8 with cams and and exhaust.
This makes me reconsider many things....
You sure you're a hipster?
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
    • Sounds good, we will aim to be there! @The Bogan I'll give you a shout if you are heading up to campbelltown for the meet too.
    • Before I get to the test day, just to finish off the android head unit. This is a demo from car start up....the standard/host system takes a few seconds to boot (same as all v37) but Android comes up quickly. In this vid I'm using the delivered launcher but have set the default to Agami since which is easier to navigate when if use primarily 5 apps. You can see the host system still takes over when required eg putting it in reverse, and you can switch between Android and not by holding the back button 3 sec. It is pretty responsive (fast) but you can see I had to press harder than expected a couple of times.  I still have the phone connected to the stock system, and that also seamlessly takes over Android music playing. v37-android-demo.mp4 The bigger reason that I put this in though is so that I can use Ecutek directly on the head unit. That gives me a dash with logging (up to 20MB only), high and low value warnings on any parameter etc etc. I've run a USB cable from the Ecutek OBD dongle to a USB input on the unit, easy. v37-ecutek-demo.mp4   The unit did freeze on the launcher the other day, I think Agami was trying to verify the license when it didn't have a data connection...will monitor and report back if there are any other problems but so far I'm very happy with the upgrade.
    • Nah that is just crappy GPS mapping, I did have a small excursion (cold tyres, damp track, surprise!), will post up that when I get a chance.
