Good to see employers do the right thing when left to their own devices.
As opposed to the unions let's stick it to the employer! YEAH! Promote everyone yeah! Oh wait... How'd that go for holden? Ford? Mistubishi?.. Alcoa?
Quite the trend there...
Edited by alr33x
  • Like 1
BOOM *mic drop*
Get car back on Friday
Fark yeah, engine bleeds ok, head not lifting now. Farken sweet.
Torque converter good, best mod ever
Exhaust sounding nice, really good move there too
Car driving nice, even fixed fuel tank lid
Day off, maybe take a trip through the hills
$310 tow home
You mean leveraged like with loans?
Straight cash brah.
How will/did you manage to accomplish this?
Say you worked at 20 to 30. 10 years.
You would have to be on an average salary of $220k p.a
So about $70k in tax, and say $50k in spending a year.
Would leave $100k in savings over 10 years
$310 tow home
Maybe someone put you on a Voodoo doll
need more info. what happened?
inspected a nissan cedric for someone interstate the other week. its got issues, but cheap. he's almost sold on importing a RB25DET AWD model, but isnt sure about letting this cheap one pass by (because its such a great example, not). Now he wants to express post me his OBD2 scan tool so I can see what the engine light issue is.
do i:
talk some sense into him and say get the car inspected by mechanic/workshop and use their scan tool.
or
offer to do what he asks, charging money to do it.
Nothing happened, it blew while I was overtaking a car in an overtaking lane at 110kmh in 4th gear.
The only reason I built the RB is cause, well, the original one exploded and I had free labor and my options were forged RB, or replacement standard engine, both pretty much for $0.
Plus there was a stroker kit for sale for near nothing.
It appears however that no-one can actually build this engine, so, yeah... building something so it'd be more reliable than a 15-20 year old engine... lol was not.
    • You’ll be very upset when you bust that too not to mention the gearing totally sucks. Don’t do it.
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
