Yeah that's very true
Like I said I have given this engine plenty over the years so I'm not unhappy...I've expected so much and got so much in return. The plus side is that an RB25 is all of $1000 for a second handy if it is in fact a blown head gasket. Might consider an alloy radiator for this one...
Stop killing rb25's, those engines are my Plan B when the rb20 pops.
But they're so cheap, powerful and reliable
It's actually my preferred option right now to buy a second handy and swap it in rather than pay someone to diagnose a head gasket issue, pull off the head, machine bits and replace anything wonky, then reinstall everything.
I don't have a driveway...
Dare I organise a working bee to get this shit done? Who would properly come? It would probably have to take place at Scotty's who at least has a hoist for dat dere lower car onto engine approach.
"The Birds and the bee" - help get me back on track. Free bbq and severe amounts of alcohol supplied.
  • Like 1
In for VWL engine swap. I can manage the change. Just in case the gearbox doesn't get along with the new engine & the alternator starts looking for other opportunities.
But what do you do when a rumour starts that the ecu is considering a transfer to another vehicle and neither denies nor confirms it?
  • Like 1
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
    • Sounds good, we will aim to be there! @The Bogan I'll give you a shout if you are heading up to campbelltown for the meet too.
    • Before I get to the test day, just to finish off the android head unit. This is a demo from car start up....the standard/host system takes a few seconds to boot (same as all v37) but Android comes up quickly. In this vid I'm using the delivered launcher but have set the default to Agami since which is easier to navigate when if use primarily 5 apps. You can see the host system still takes over when required eg putting it in reverse, and you can switch between Android and not by holding the back button 3 sec. It is pretty responsive (fast) but you can see I had to press harder than expected a couple of times.  I still have the phone connected to the stock system, and that also seamlessly takes over Android music playing. v37-android-demo.mp4 The bigger reason that I put this in though is so that I can use Ecutek directly on the head unit. That gives me a dash with logging (up to 20MB only), high and low value warnings on any parameter etc etc. I've run a USB cable from the Ecutek OBD dongle to a USB input on the unit, easy. v37-ecutek-demo.mp4   The unit did freeze on the launcher the other day, I think Agami was trying to verify the license when it didn't have a data connection...will monitor and report back if there are any other problems but so far I'm very happy with the upgrade.
    • Nah that is just crappy GPS mapping, I did have a small excursion (cold tyres, damp track, surprise!), will post up that when I get a chance.
