Vic Wasteland Thread - 15.0
By r33.antwone · Posted
hello wanted some insight on what my problem could be so i swapped a RB26DETT into my r33 gtst used a R33 GTR engine harness and im using a haltech platinum pro. The car cranks but no start the ecu isn’t getting any power now im trying to find out why i cant seem to find any schematics or diagram for the engine harness for the r33 gtr anything helps thank you. -
By DraftySquash · Posted
hahahaa @GTSBoy that is my last resort. Like use a cardboard and cut it using the indicator as a reference. But I was winging my luck to see anyone had a spare bumper because drawing the outline off the hole is always easier and less chance of mucking it up -
Admittedly in that screenshot its doing about 13psi but later on in the log theres definitely spikes to 16. What is missing though is the massive peak, then a big drop and then a recovery. While it does go a little higher than I would like on base pressure, I think it's reasonably safe to assume that boost control via the mac valve should be a lot easier to control from here on out. I wasn't game to hook up the mac valve today as it's very wet and it's on the verge of fighting traction as it is.
I think this is still wrong. There is something crappy with wastegate priority (or the f**king absence of it) if you can't get below nearly double the base spring pressure. But if you're happy with what you've got, upload skid vids now.
So a further update for this one. Turbosmart were very gracious and took one look at the wastegate and said this is our original version, we will just replace the entire thing and send it back to you. So I fitted the new wastegate with its new revisions and took it around the block on spring pressure (9 psi spring). Appears the minimum it will do is about 16psi. Keep in mind this is only 2nd and 3rd gear pulls. I think the issue is fixed compared to what it was doing before however I'm happy to provide more logs if anyone thinks theres more to the story to uncover
