will someone please think of the 400 kids who didnt get to play sport in caulfield due to lack of parks
http://www.theage.com.au/victoria/the-public-space-that-people-didnt-know-existed-20160220-gmz66o.html
a mate just asked me about a "stage 2" kit for my car
Goodbye cruel world
LOL
it is an issue. they have effectively built a racetrack around public land and are not paying appropriate rent for it because the land rests in a trust of which 40% of the controlling vote are members of the MRC.
we dropped in on the way past and it's a fair shithole and could be used far more effectively.
im not defending the racecourse members club, just seemed silly to suggest the space could be used for childrens sporting clubs and that 400 kids missed out on playing sport
</script>B0QQOmSIgAAePTI.jpg&&0){for(var>
Can't comment as it may or may not be true, but there are a LOT of ovals in that area
side note... we drove past a new outdoor waterpark just near there that is under construction and looks f**king awesome
whos got the pics of martin putting his car into the wall? i want to show the kid that works for me how he may die.
https://picasaweb.google.com/100203254234701302909/200sx02#
http://youtu.be/JjzhqlnG-Wo
Basiclly I did everything stupid you can do.
That was 100% my stupidity.
I've done a bunch of driver training for newbies first thing I tell them you never set a record lap first thing in the day.
Take it easy warm into the track and then start pushing it.
So first thing on a 2 day track da, on a cold greasy track with cold semis I hit the throttle
Don't blame the car.
On a plus note car looks crap but still straight and still is happy doing laps and or limiter bashing on skid pans.
I knew tassie was having electricity issues since December, and had heard things were being kept a bit hush hush.
Dams there are under 15% capacity and apparently using around 1% a week, supposedly they can run to a theoretical 6.5% but has never been done before. A few big industries have been asked to shut down and apparently are being compensated. That, plus big back-up generators are being put online would cost a fortune. Hiring a big-ass generator is costing $20mil and will cost $11mil per month to run. ouch.
http://www.premier.tas.gov.au/releases/energy_supply_update
Over 300MW of power comes from wind, which apparently operates at 40% capacity on average.
Temporary diesel and gas generators are being organised or have already been turned on, and a 200MW temporary generator puts into perspective how small a part wind really plays. You cant rely on that shit in an emergency!
    • @666DAN sorry to bring you and old thread.     I've got my de+t done and it's all running great other than 1 small issue.    Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd when selected . But nothing when in  drive or what gear your in when you pop it into tiptronic. I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Do ya have any ideas?     Cheers man
    • Well I recently changed my rear axles and was thinking if I bumped anything, I have been driving the car for a while now though... But it has been raining today so everything is wet under the wheel arches. Brakes feel fine and can't hear any of the metal screamers, I had a squeak coming from one of the handbrake drums but that seems to have gone away a while ago. I was going down a hill when it lit up and I did feel the abs bite for a second and question why it did it?
    • Correct. Um. I dunno. I haven't cared enough about the way that the NA cars work to know for sure. But..... The 33/34 turbo manual cars have an electronic speed sensor in the gearbox that outputs a +/- (ie, sawtooth AC) voltage signal. That is connected to the speedo. The speedo then outputs a 0-5v square wave (ie, PWM) signal that the ECU (and any other CU on the bus) sees. The speed sensor is NOT directly connected to the ECU. So here's the problem. Your new ECU expects to see the PWM signal, but must somehow be getting a direct signal from the diff speed sensor. Which would suggest that the wiring of the NA car is not the same as the turbo cars. I think you will need to spend some time with (hopefully the wiring diagram for the car) and a multimeter to see what is connected to what. Then, presuming I am correct**, you would then want to separate the ECU speed signal input from the rest of the car's wiring, and probably either buy a speed signal converter, or build one using an arduino (or similar). That would take in the speed sensor signal and output a scaled (and suitably rearranged) signal for the ECU. ** We shouldn't presume that I am correct here, because there might be something else crazy going on. I don't think you could convert the speedo to be fed from the gearbox sensor, because the pulse rate from that sensor is probably different to the diff sensor and then the speedo would read wrongly. And this also wouldn't fix the ECU's problem either, because the ECU doesn't want to see the gearbox signal direct either (assuming that they are all on the same wiring, for some odd NA related reason, see above caveat!) Does this help? Probably not. Can you make it work? Almost certainly. With the above work. You should buy a handheld oscilloscope from Aliexpress so that you can view these signals directly. Connect up the probes and drive the car. Show photos of the screen when drving at known speeds and connected to different places, and we'll see what we can learn about it.
    • Assuming your brake pads are not worn right down, I'd add a little brake fluid. Is there any sign of a brake fluid leak?
    • Hello all,  I need of some help. On my drive home my handbrake light lit up and started flashing. When I got home I checked my handbrake sensor under the centre console and nothing seemed out of the ordinary. I have scanned my car via the consult port, no codes shown. Checked my brake fluid as well which is half full. Tried unplugging the brake master but it didn't change anything. Thoughts on what it could be? The master float doesn't seem to be stuck. My car is an 1998 ER34 sedan GT. No hicas but has ABS Photos below 👇🏾
